Question about Yamaha Full-Size Keyboard
No sound from Yamaha keyboard
It was fine until one day it cratered for no apparent reason, making only scratchy barely audible sounds and now it is totally silent. I want some one to come here and fix it as I am clueless.
I have it set up to play through a computer. the computer sound works fine and the playback device is activated. should I just toss it out? Help.... thanks,
  • bashamee Jul 08, 2010
    your other guy said take it to a repairman. well there are not any in this area who will repair electronic keyboards. so I am stuck with trying to fix it myself and his advice didn't help solve the problem. PS I am unable to pack it up & ship it someplace as its permanently affixed to the stand. thanks.
  • Jake Soluman Aug 18, 2013
    i have the same exact problem with my Psre423
    Genius:
  • 1,040 Answers
Since your keyboard works fine with the PC. That means the problem is with the keyboard's Speaker. Either your speaker cable or speaker itself is not working... you have to identify that whether the problem is of speaker wire or speaker.... see that whether the service manual of your gadget is available or not.. if available then purchase the same. It will help you a lot for while repairing
Hope this has helped you....
Thanks...
Posted on Jul 08, 2010
  • 1 more comment
    I am sorry that you thought I said my keyboard works fine through the computer. NO! I said, the computer is fine; I meant the computer system sound is working and so are the computer's speakers. It is the Keyboard itself that does not work--it is totally silent when its keys are pressed.
    also, the lighted part that shows the function has disappeared. it still lights up, but the function, (i.e. "Grand Piano 100") no longer shows.
    I have bought new batteries for it and will try to replace them myself if I can figure out how to open the battery compartment. it's conveniently placed on the instrument's bottom where I can't see it, according to the manual. Let me know if you have any other ideas, or if anyone is a Yamaha expert, that's who I need. Thanks, Sylvia
  • jeremyevents Dec 30, 2010
    I just had a similar symtom... and I fixed it. Turned out the plug in the wall came loose and the keyboard was being powered by the not so new batteries!
  • Raymundo Mota Jun 25, 2018
    I turned on my keyboard with the highest volume and it makes no noise
This isn't a solution. I just wanted to say the same just happened to my Yamaha dgx220 after I hooked it to my computer.
I just tried to play a midi file and the speakers broke. It's out of warranty and with today's technology it's usually cheaper to replace than to fix!
Posted on Dec 29, 2010
  • Yamaha Master
  • 6,993 Answers
The keyboard takes only a specialist to fix the problem. Its also very delicate. The best you can do is to reset it and if the resetting does not work, then you will have to take the keyboard to a repairman to fix it for you.
Firstly, connect a headphone to the keyboard and observe if it will give a good sound. if it gives a good sound, then it means the speaker for your keyboard may have loosed contact or gotten burst.
But if it does not make any sound with the headphone, then it might be a board or sound ic problem. You can also try resetting the resetting the keyboard to default.
Turn off the keyboard, press and hold the last white key and turn the keyboard on while still holding the white key. The keyboard will then restore to its factory default.
If that doesn't solve the problem, you will have to dismantle the keyboard, use a meter to read the panel/board in order to detect the fault and do every necessary replacement. Also, you can do a deep cleaning, by cleaning all the dust in it.
If you can't do any of this, then you will end up taking is to a repairing man to fix the problem for you.
Good luck.
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Fender troubleshooting
Replace the selector switch. $15 DIY or $40-$50 Pro installed.
Jul 27, 2014 | Fender Modern Player Telecaster Thinline...
Popped lights on no sound
Probably smoked the output IC(it is the chip mounted to the heat sink attached to the fan) which can be purchased from marshall directly or from one of their service centers. Also P-H216 sold at tubesandmore.com should work. No soldering required. Look at that IC(chip) to see if it looks burnt or has a crater on it which would indicate that that is indeed you bad component.
Mar 18, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
Korg Microkorg XL Vocoder Not Working (No Sound)
Check the mic and connections all through its input into the unit. I would check the cartridge of the mic for continuity for the reason that (I think but not 100% sure) on this model, I think there has to be sound at the mic or it does go silent in vocode mode. This is how it digitizes the mic and keys together. The played keys cannot put onto pitch the sound it is NOT picking up at the mic. I think there is a problem with the mic.
Mar 07, 2014 | Korg Micro Microkorg Xl Synthesizer...
Monitor buzz
its poor insulation on your power supply
Aug 27, 2012 | Music
There is a scratchy sound when the overdrive is engaged. Its not a hiss but a scratchy sound that is noticeable when you hit a cord or note and its fading out
There likely is a component failure. Possibly an electrolytic capacitor. Also low voltage due to failing power adapter or depleted battery would cause this. Do NOT count on LED for battery health..
May 17, 2011 | Keeley TS808 True Bypass Modded Guitar...
Scratchy volume potentiometer
Try cleaning your volume potentiomenter with contact cleaner (they come in spray can's), the scratchy sound is audible when you turn your volume control on, the contacts inside your potentiometer accumulated dust or some other particles.
Aug 11, 2010 | Alesis Sr 16 Stereo Drum Machine
Spider III amp stopped making sound
After making sure your guitar cable is OK (they often cause the problem) check the inout jack on the amp. They often get broken by yanking cable sideways.
Oct 26, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
My Guitar Amp Started Squeiling And Now It Is Barely Audible.
There is little or no hope that this can be fixed at home, sorry . If it lights up and you have power and still no sound, it may be simi cooked, not to say it couldn't be fixed. But lots of times these days Tecs want as much to repair as a new one. Balanceit out for a new one , to the repair cost . You may just find a new one is the way to go.But never toss out, junk is someones treasure. good luck DFD
Apr 09, 2009 | Yamaha Music
Low Sound
First of all what model your keyboard? Posible couse of audible sound is came from the volume control. Replace the volume control or contact an authorize service center on your location.
Jun 08, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
4,871 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
