Question about LG WM-2277HW Front Load Washer
Our front load washer is 3 mos old and the clothes have a must odor. We have tried all suggestions to no avail. Please advise the true nature of the problem and solution.
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!#
Posted on Sep 28, 2010
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Smelly washer
To compare washer cleaners go to: http://www.youtube.com/watch?v=Ua6OJPn0-fU
To remove mold odor from your washer, towels and clothing safely and easily use Smelly Washer Cleaner. It advantages over others:
24 treatments compared to 1-3 for competitors.
It's completely natural.
The only washer cleaner available that also removes odor from towels and clothing.
It's cheaper! Even ordered from our website it's less than $0.71 per use!
Jun 10, 2010 | Kenmore 24902 Top Load Washer
Washer makes clothes smell like dog
Hello there:
please follow these simple steps
Instructions Things You'll Need:
  1. Step 1 Balance your washing machine. Standing water breeds mildew and mold. A washing machine that isn't level to the ground stands a higher chance of not draining completely. Take a level and place it on the top of the machine along the front from side to side and then again along the side from front to back. If the machine is very off, you can adjust the feet to compensate or add something under one of the feet if it is not flat against the ground. Portable washing machines are especially prone to have standing water because they are moved around and not leveled each time.
  2. Step 2 Promptly remove your clothes at the end of a wash cycle. If you regularly leave the damp clothes in the washing machine for an extended period at the end of the cycle, you will have mildew in your clothes and your machine. The same is true if you put clean clothes in the dryer and they are not completely dry when the cycle ends and you don't go back for a few days to pull them out. Damp clothes in an enclosed space for days will mildew.
  3. Step 3 Leave your washing machine door open in between uses which gives the machine the opportunity to fully dry out.
  4. Step 4 Use white distilled vinegar in an empty machine. Run a load with only hot water and two cups of vinegar to clean out the machine and freshen the scent. Vinegar naturally eliminates odors and reduces the buildup of soap residue in the washer which contributes to mildew development. You can also add baking soda and/or bleach to the load for both their sanitizing properties as well as assisting in ridding the smell of mildew.
  5. Step 5 Regularly use vinegar when you wash your clothes. Add 1 cup of white distilled vinegar to the last rinse cycle. Vinegar has acidic properties but it is mild enough that it will not harm your fabric. It does dissolve alkalines in laundry detergent which makes for cleaner and softer clothes. The reduction of detergent buildup in your machine will help to also reduce the incidence of mildew.
  6. Step 6 If you have a front load washer, they are particularly prone to mildew and mold. Follow the manufacturers suggestion as to how much and what type of detergent should be used. It is generally less than the traditional top load washing machines. Once again, additional soap residue helps to breed mold and mildew. Also, pull the seals back from around the door and make sure there isn't a build up underneath them that needs to be cleaned out.
  7. Step 7 Finally, if you have done all of the above and nothing seems to work there are commercial products available that are recommended.
Dec 26, 2009 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can't get rid of odor on clothes and washer I have run the bleach through as suggested in manual,have used very hot water and I leave the door open when not in use.PLEASE HELP!
in order to get the odor out of the clothes, you first have to fix the washer. it is likely a build up of soap scum which is smelling. are you using the correct soap for you front loader? HE soap. there is a product on the market called Afresh, a package of 3 tablets. buy some and use all 3 in the machine and run it empty. then follow the directions on the pack for monthly maintenance.
Oct 16, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Soap left in clothes
hope you are using he detergents (high effeciency low suds) also if you have soft water oversudsing can occur even with he ..try reducing amount ..also have been told tide he detergent tends to suds more so may try switching detergent brands try runing washer with no soap no clothes begore next load to flush out any detergent that may remain ..be sure to run washer with bleach no clothes on short cycle peroidically to avoid mold/mildew odors that front loads tend to acquire after a few months use and leave door open if possible between uses..let me know about detergent thanks
Jul 15, 2008 | Kenmore 44102 Front Load Washer
Kenmore Washer Odor
Meoser,
I've been selling the only available all natural washing machine and towel mold and mildew remover online at smellywasher.com since 2006.
It's now also available at Ace, Tru Value, Hardware Hank and Do It Best hardware stores. One bottle provides 24 treatments and guarantees to remove mold, mildew, or any odor from your washer. After the washer is cleaned it also safely and easily gets rid of the mildew smell from any towel or clothing that the odor has transferred to.
The dark, moist environment of your clothes washer is the perfect place for mold and bacteria to grow. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change that environment but we can stop the food source for them to grow buy reducing the amount of detergent used and stopping fabric softener use. Go to the blog page at smellywasher.com to read advice on the cause of and cure for washing machine and towel odor.
Nov 06, 2007 | Washing Machines
Washer shakes, as if out of balance, after all water is drained
Biggest problem i get on the front load machines are spinning and draining problems. First thing to check is make sure your soap is not foaming up. If you see alot of suds in the machine when it is washing switch brands h.e. soap is best but he liquid tide has been a big problem with suds. Next make sure you put equal size items don't mix heavy and light items in machine as this may have off balance issues! Next check the coin and pintrap if it has one some machines have filters on the front of the machine that need cleaning.After these have been checked see if the machine has any unusual noises or odors when used rubber burning odor or electrical odor when in use may indicate a overloading or internal problem with the machine.
Oct 09, 2007 | GE WSXH208A Front Load Washer
LG WM-2277HW Front Load Washer Logo
90 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
