Back to:
Tags:
Nokia N70 Cellular Phone
How can i unlock nokia n75 (by 3 users)
posted by 916vito on Apr 18, 2008
i bought nokia n75 , usa cingular provider, can you help me to unlock this phone, IMEI:354815010436155
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Aug 17, 2008
kllllllllllllllllllllllllllllllll.;lp['
Comment by ritz061086, posted on Jun 28, 2008
i have n75 from usa and i get it lock in india so how i can unlock
Clarification Request
by ILIJANRUZA, posted on Aug 30, 2008
NOKIA N75 CINGULAR USA IME.. 354815010702952 ..someone plzz help wit unlock code .. cant find the software ,, and instructions ,,plzzzzzzzzzzzzz,, thank you
Best Solution
posted on May 07, 2008
FixYa! (100)
adiya
Rank:Apprentice Apprentice
Rating: 94%, 8 votes
Some one can help me to unlock nokia n 75 IMEI #354815012823285
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how can i unlock nokia n75:
I don't want to Accept this solution
Solution #2
posted on Apr 20, 2008
Helpful (85)
ahlrub
Rank:Wiz Wiz
Rating: 82%, 138 votes
cant do this here man,, u gotta go to the pro's they'll do it like this put cables in phone , run the soft and open locks..... a word of advice dont publish your imei somebody can mess it up like a pie for all seasons...
Thank You!
Solution #3
posted on May 13, 2008
Helpful (85)
PauldLucky
Rank:Wiz Wiz
Rating: 85%, 130 votes
A word of advice dont publish your imei somebody can mess it up like a pie for all seasons.
Before trying anything else, contact your service provider and ask for an unlock code.
Usually, if you've been a customer of theirs for some time, they will provide you with an unlock code for free. This is, by far, the best way to get your phone unlocked.
Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia N70 phone, select the model N70, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code (MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that says "SIM is not restricted" or "Restriction off" message depending on your model.
If not, try entering another code. Message "Cannot undo restrictions" means the phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies, cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on. Keep the buttons held down till you see the word "Formatting..." on the screen. Make sure that the battery is full charged before you attempt this. This should reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked without using special equipment.
Most of the newer phones will not work with the codes generated by the free unlock programs.
You can get a free unlock code generatoe software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
Good Luck.
Live, Love, Laugh.
Thank You!
Solution #4
posted on Oct 03, 2008
Not Rated (0)
FAYAZMULJI
Rating: 0%, 0 votes
RAYSAGEM PLZ HELP ME DEAR I HAVE N75 OF CINGULAR AND AT&T HOW CAN I UNLOCK THE CODE
Comment by FAYAZMULJI, posted on Oct 03, 2008
PLZ HELP ME DEAR MY EMAIL ID IS UN4GETABLELUV@HOTMAIL.COM
Thank You!
Solution #5
Not Rated (0)
Guest
Rating: 0%, 0 votes
SOME BADY HELP ME I HAVE N75 OF CINGULAR HOW CAN I BREAK THE CODE PLZ ADD ME ON UN4GETABLELUV@HOTMAIL.COM
Thank You!
Solution #6
Not Rated (0)
ILIJANRUZA
Rating: 0%, 0 votes
NOKIA N75 CINGULAR USA IME.. 354815010702952 .. need unlock code someone hekp plzzzzzzzzzzzzzz,, and instuctions ,, thnk you
Thank You!
Solution #7
posted on Aug 21, 2008
Not Rated (0)
Rankitt
Rating: 0%, 0 votes
Hi Raysagem,
could you please provide me your contact number so that i can give u my n75 IMEI number so that if u can help me out getting the unlock code for the same. thanks a ton for your help.
Thank You!
Solution #8
posted on Aug 14, 2008
Not Rated (0)
hawk_007
Rating: 0%, 0 votes
Can anyone give me unlock code for my N75 using AT&T/Cingular network with this IMEI# 354815010019860 ? TIA.
Thank You!
Solution #9
posted on Jun 15, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Supply nokia samsung moto Motorola unlocking card,software it is Very convenient. Wvelcome Contact with me MSN:Linwenyang03@hotmail.com
Thank You!
Solution #10
Not Rated (0)
Raysagem
Rank:Wiz Wiz
Rating: 83%, 1033 votes
The codes do not always work, due to various reasons, for example your phone might have had a software (firmware) update. Or Cingular Pacific Bell Wireless might have foreseen this, and they will have an extra bug in the device to prevent it being unlocked. Good luck!
Usage:
To get code You need:
- Network code (network which locked the phone)
- IMEI number (15 digits)
- Phone model, ex: “Nokia 6310”
To enter the code to the phone (switch on without SIM card).
Input the Code in the phone as follows:
#pw+??????????????+1#
#pw+??????????????+2#
#pw+??????????????+3#
#pw+??????????????+4#
#pw+??????????????+5#
#pw+??????????????+6#
#pw+??????????????+7#
Here: ?????????????? You should enter generated code.
First code in the end of the string must be added + 1#
Code number 7 in the end of the string must be added + 7#
If you have proper software and You know on which lock, phone
is closed just simply enter proper CODE.
If YOU DONT KNOW – which lock is closed do the following:
1. Enter the first code, if it’s the wrong code – WAIT 30 seconds!!! And then:
2. Enter the code number seven this will open all locks.
How to get ‘p’ ‘w’ ‘+’ signs?
Press
* several times on keyboard of phone...
Now a message should appear something like “Sim restriction off”. That means your phone is now unlocked.
!!Warning!!
If the codes don’t work after entering 5 codes You will lock the ‘CODE UNLOCK FUNCTION’ and it will be possible to unlock the phone only by using a cable/device.
Network 31017000=CINGULAR - Pacific Bell Wireless;U.S.A.
IMEI 354815010436155
Nokia N75
Your code's are:
#pw+788160416653167+1#
#pw+075153702333051+2#
#pw+122404557046502+3#
#pw+345366571345760+4#
#pw+346226471424725+5#
#pw+446877070440073+6#
#pw+927512552537416+7#
"Confucius he say: Man who sneezes without tissue takes matters in own hands."
Thank You!
Can you Help with these Cellular Phones problems?
Hi, I was updating my cell phone software, while updating...
Dear coordinator Here is the description to my phone...
im having a problem with my n70 phone
my nokia n70 serial number 3532690174587 getting offline...
when i upgraded my software with the nokia upgrade...
Loading problems.
Repair Service
Find Cellular Phone Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
