Question about Cameras
I have a Nikon CoolPix P1 and the lense cover will not open fully without a couple of taps once the on/off button is pushed. I tried using a CPU air can to no avail
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the issue.
Thanks.
Posted on Jul 14, 2010
Coolpix s3300 lense stuck in
Contact the Nikon USA Repair Center at 1-800-645-6687 9AM-8PM EST, Monday to Friday, for instructions for obtaining a free estimate for repair. Your camera has damage that you will probably not be able to fix yourself.
Feb 10, 2014 | Nikon Coolpix S3300 Digital Camera Silver
Good day, pleas help me. My nikon p7000 turns on without fully opening the lens cover . I have to push back the lamells each time. I am already out of the warranty time. Do you have a suggestion, how to...
Seems like it's a mechanical damage. Since this is an compact camera, I would not reccomend opening it or trying anything it if you can already fix the problem manually and it doesn't affect the photos or anything else.
If you're still concerned about it, you can go to official Nikon service.
Oct 12, 2013 | Nikon Coolpix P7000 Black 101megapixel...
Nikon Coolpix 4600. Lense cover does not close when camera is turned off or fully open when camera is turned on. I can move it all the way open with my fingernail. Seems like mechanical mechanism is...
Any sand in a compact camera is bad news - repair will be expensive. In your situation, I would continue to use the camera while it still works, and give serious thought to a replacement.
Jul 20, 2017 | Nikon Coolpix 4600 Digital Camera
My nikon coolpix s210 shows lens error
Hey digi_5
This is a common problem with Nikon and it isn't covered under warranty since Nikon sees it as an error resulting from usage. Apparently, the Coolpix is pretty delicate and any slight bump can cause a lens error.
Some people have tried gently twisting the camera lens back into place or gently tapping/bumping the side of camera.
If neither of those work, I'd say try getting the camera repaired professionally - if it isn't covered by Nikon, they'll charge you heavily. I've used Teleplan Camera Repair before and they're cheap compared to other places.
I've heard that once the camera is fixed, turn it to the Playback mode before turning it off - it apparently helps avoid the problem altogether.
Apr 16, 2010 | Nikon Coolpix S210 Digital Camera
Lense Error
I have a solution for Nikon coolpix S5/S6. You can try my document "nikon s5 s6 lens cover error repair.doc"  uploaded on site
http://www.esnips.com/web/papputatiyasStuff
Regards Mukesh
Dec 30, 2008 | Nikon COOLPIX S6 Digital Camera
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
Lens would no move Nikon Coolpix P1
Did you send shop repair problem Lens??
Feb 01, 2008 | Nikon Coolpix P1 Digital Camera
Nikon Coolpix S5 lens cover won't open
Hi Debscan, My 1.4 year old S5 developed the same problem and after checking out various websites I get the impression that it is a common one to these cameras. I found that if I put the camera on a level table and then turn it on (and off) 3 times the lens cover would open further with each try. On the third turn-on the lens cover would drop fully with a definite "Click" and the camera would work. The next time I shut it off, the lens would not close properly, but the same "Third times the charm" routine would always work. This may only delay the inevidable final crash of the camera, but it might get you a few more pictures out of it.
May 22, 2007 | Nikon COOLPIX S5 Digital Camera
I dropped my camera and the lens got stuck
I banged mine around several times and tried to force the retractable lens in and out. Neither of these things worked. I finally thought "what the heck it's broken anyway" and used a bobby pin to try to force the outer lens cover off. After applying just slight pressure it unjambed the lens cover and it works fine now.
Dec 29, 2006 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
