Question about Nokia N95 Cellular Phone
Applications not being installed
My phone (N95-8GB) had stopped working and each time I switched it on it would say erase some phone memory, whereas actually i didnt have anything stored in the phone memory.
As a result ii gor my phone formatted. After that, it does not Install any applications. It does download them though, and when the installation process comes, it says "your phone data setting are incorrect." Please advise me how to correct this...I even tried to correct the problem by restoring factory settings, but with no success.
  • sam_cash17 Jul 09, 2010
    Can u help me out further? I have done what you have said. I have formatted my phone but still whenever i install any application, it says 'license expired or your phone's data settings may be incorrect'.....
    I'm sure the license is not expired of the applications i wish to install. Thus the data settings is the problem....can u help me how to correct the data settings....i have also updated the software to 31.02 but still its the same......PLEASE HELP
  • 4 Answers
Copy all data to pc or memory stick and formet with code *#7370#
Posted on Jul 06, 2010
Hi I am using nokia c6. When i open any photo or browsing internet, it says 'memory full delete some application'. Whereas unuse phone memory is 120mb. Recent I updated firmware. Please help.
You need to move many of your applications to the memory card, also clear you internet cache, set at smaller size and store it on the memory card. This is common for most smartphone
Jul 10, 2011 | Nokia C6 Smartphone
My nokia 72 phone showing memory full,close some application. whereas it is not full, i have formatted the phone memory.. but i cant open my message inbox
you need to reprogram you phone install a new software to upgrade your phone, you cant open your messages in inbox because you reach the phone memory already, the memory was corrupted
Jun 07, 2011 | Nokia N72 Cellular Phone
I upgraded the Android system for my sanyo zio and now i can't recieve any text messeges cause it says that the memory is full and it also says that my phone memory is full eventhough iv'e been erasing...
It seems most of you applications are stored in the Phone Memory and/or your application data is taking up lot of memory. You actually don't have to erase/uninstall applications. Please consider performing the following steps:
  1. Go to Settings --> Applications --> Manage Applications. In this Menu you'll be shown a list of applications. Use the Menu Button to "Sort by Size" and get a list of the applications sorted from high memory usage to low (phone memory). Once this is done, you'll be able to view the memory being used by each of the applications. Click on the applications which you see are consuming more memory and then use the "Clear Data" button to clean up the data being stored by the applications to free up memory. This clears up any cache, cookie, temp files associated with the applications. Depending on your android version, you may also see an additional button "Move to SD Card". The best option to get more space would be to use this button and move the application to the 4 GB SD Card storage.
  2. Optional Step if you do not have "Move to Phone/SD Card" option available - From the Android Market, download and install "App 2 SD Free". Once done, this application should help you free up a lot of space by moving applications from your phone memory to the SD card.
Hope this was helpful. If so, please consider rating this solution.
-thanks,
M
Mar 09, 2011 | Computers & Internet
Phone memory low delete some data i cleared all privacy and cookies and catch all messages i dont have no games on my phone memory no apps are running there is alot of mdip on my phone memory but dont know...
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Jan 08, 2011 | Nokia E71 Smartphone
Why can't i open my message folder.it says message storage memory full,whereas its not..
Its because of the Ram being used highly by some application. Check whether there is any high end applications like games or something installed, if it is try uninstalling it and check again. Good Luck
Dec 28, 2010 | Nokia 5130 XpressMusic Red Unlocked Import...
My installation fails every time when i want to install anything
hi friend N70 IS supporting jar and sis files
what type of error are you getting while installing application on N70 is it certificate error or untrusted software /application
make sure to use the current date/time set it correctly
___________________________________________
if you phone is having problem then do the below steps
Soft Reset The reset will restore all the phone’s settings to factory default.
*#7370# Hard Reset Please make backup before applying this type of reset, since it will restore the phone’s settings as well as erasing all the data in the phone memory.
  1. Switch off the phone.
  2. Press CALL + * + 3 + ON simultaneously until the phone is completely started.
note: The default password is 12345. You need to press and hold the key until the number appear.
backup your contact /data and do the steps
to install an unsigned software you have to digitally sign the software using certificates
visit
www.getjar.com to download applications
http://nokia-n70-software.epocware.com/
Mar 31, 2010 | Nokia N70 Cellular Phone
The T-Mobile WING has to be rebooted to run another application
You might try searching forums.xda-developers.com
They have a Wing/Herald section and they have custom ROMs.
I am running Windows Mobile 6.1 using the OpenTouch v7.5 Pro. It's not great due to the lack of hardware that HTC built the phone with. My best solution for this problem is tough it out until the HTC Touch Pro II (will likely be called the T-Mobile Wing II) is released, which will have better hardware (but not by much); or get an iPhone. I will likely be switching when my T-Mobile contract expires in the fall.
Jul 06, 2009 | T-Mobile Wing™ Smartphone
Messages say resend all the time in d outbox
This is not a question of your phone's external it says for internal or workable memory of RAM. RAM is for providing room to running application. In your phone RAM is seems stuck and you have to empty it by formatting. For that backup your data and reset your phone by entering code string *#7370# and it will work again properly.
Jan 12, 2008 | Nokia 6630 Cellular Phone
N95 phone says installing when switched on
software damage now open the set and heat it flash
Dec 19, 2007 | Nokia N95 Cellular Phone
Problem is""phone star-up failed. contact the retailer"
The best solution for this problem is to format the phone memory. U may think format will erase all applications but it is false . The essential softwares like mp3 player, camera, etc. are not erased.
The process for format of phone is :
1) turn off the mobile.
2) press and hold ( green dial button + 3 keypad + * ) and turn on the phone holding these 3 buttons(dial button + 3 + *) until formatting screen appears.
3) When formatting screen appears, just leave the keys. and ur phone is formatted now.
4) When finished, it asks for restart of phone.
5) Restart ur phone, and ur phone is ready.
Sep 09, 2007 | Nokia 3230
Nokia N95 Cellular Phone Logo
64 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
