Question about Dremel 400 Xpr Rotary Tool
Dremel 400 digital- turn on switch nothing happen. however if turn the shaft by hand the engine starts up very slowly. thats all though does not run at speed. no burning
rowdy45176
  • 2176 Answers
SOURCE: broken flex shaft on Dremel model 232 broke
You can go to Dremel.com and find assistance or call their toll free number at 1-800-437-3635 and speak with their tech assistance. Let me know if you still need more help. Also I tried using the model number provided and it came up empty that is why I am directing you to this site yourself.
Posted on Feb 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need to replace the bent shaft that the chuck screws onto
I would go direct to Dremel.com or call them at 1-800-437-3635 and get the schematic and parts you need, I just checked and they have a parts diagram online that you can view. go to the section about manuals/literature and type in your model number. Good luck
Posted on Mar 16, 2009
miket756
  • 2702 Answers
SOURCE: Dremel 400 xpr stopped while in use and started to
its a comon thing with a dremel to just burn out in use iv got through 3 of them all died the same way
Posted on Oct 25, 2009
  • 597 Answers
SOURCE: My Dremel tool motor still works but shaft won't turn?
From looking at manual there is no transmission or connector so the only possible explanation is that the shaft is broken. You might try calling this number
1-800-437-3635 to see if they repair or can further advise you.
Posted on Dec 06, 2009
SOURCE: Is the bigger Dremel 400 XPR coming to Australia ?
yes already there you can buy at Just Tools
Posted on Feb 20, 2010
How do / What do U do to lock on/hold to to a tool,s working shaft ???
If I properly understand your question, it sounds like you probably want to loosen [unscrew] the collet nut in order to remove and exchange tool bits.
If THAT is the issue, then the answer is that it is not necessary to "hold" the shaft with any kind of hand-tool!
Dremel, and most of its imitators, install a "pin" type shaft lock right near the collet nut.
When gently pressed inward, the pin engages with a SINGLE hole in the shaft. This means you must gently hold the pin down against the shaft while very slowly turning the shaft with your fingers only.
When the hole in the shaft comes into alignment with the pin, your finger pressure will cause the pin to fully insert into the shaft hole, effectively "locking" the shaft.
As the pin is spring loaded to keep it away from the shaft, you must continue to hold the pin down until you have finished installing a tool bit, or finished whatever operation you intended. Or, if you release it, just go through the locking process again when needed!
Jun 30, 2016 | Dremel Model 219 5-amp Solid State Motor...
Tool turn on and seems to run, but working end does not turn. I took it apart anf the plastic bushing on the metal shaft is stripped. It also sems like the metal shaft may be worn. Can I buy replacement...
Hi Joe, Joe here. I have a dremel tool now for almost 25 years. Same one. I had this happen to me. You should be able to get the parts at any hardware store that has the big dremel accessories cabinet. You can also get the parts from dremel's customer service. Great tool, next to my leatherman wave. http://www.dremel.com/en-us/Tools/Pages/RetiredProducts.aspx
Jan 31, 2011 | Dremel Variable - Speed Multipro Rotary...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a collet nut that will not loosen. at one point while turning the shaft lock button pops up; even when pressed
Sorry, but I seem to have ( essentially ) the same problem... no positive lock. holding the button down while rotating the shaft to find the "best hold" then applying extra pressure sometimes helps. I had no problem with an older model. 400 XPR also seems to overhheat badly.
My ultimate solution: purchasing the model 4000.
Apr 25, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
Need a replacement flexible shaft attachment . when i took flexible shaft off a piece appr. 2" long pulled out of shaft
The part you need is available at most Lowes and Home Depot stores. You can also order it online directly from Dremel. Ckeck your manual for the part number.
Mar 05, 2010 | Dremel 400 Xpr Rotary Tool
Broken Dremmel tool spindle stop turning but motor runs
I called Dremmel tech support FOR FREE and they told me what was broken - flex coupling between shaft and spindle. Only Dremmel model 395 type 2 and 3 have these couplings. Mailed out repair kit yesterday.
Dec 23, 2009 | Dremel & Stylus Lithium Ion Cordless...
Flex shaft becoming hot during use, this hasn't always happened. with just a minute or less of use it is heating up to the point it can't be held
remove the flex shaft from the tool and check to see if it turns freely .. if not then try lubing the end bearigs .. use light machine oil ..not wd40 ...
Nov 05, 2009 | Dremel 400 Xpr Rotary Tool
Flexible shaft not working all-in-one rotary tool
check and see if you have the right collet insert in the chuck if it is too big it wont lock the shaft. does the chuck turn? if so your collet is not locking the flex shaft
Jul 09, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
I have a Dremel Single Speed Model 275 that belonged to my Dad. It suddenly won't turn on the end even though the motor is running at full speed. When I take my fingers and twist the end, it starts to turn...
The Dremel 275 (and other series) have a plastic coupler and spline that connect the motor shaft to the collet shaft (where the tools attach). The plastic fatigues and disintegrates, causing the collet shaft to stop, even if the motor is still running. The fix is about $5.00 --- two parts from Dremel. The 275 case is a **** shell that opens with the removal of six T-10 Torx screws.
Mar 28, 2009 | Dremel Tools & Hardware - Others
Mar 16, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
Dremel 400 Xpr Rotary Tool Logo
124 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
