Question about Sony Cyber-Shot DSC-S40 Digital Camera
Pronounced shadows on people in indoor photos
When I take indoor photos of people, sometimes there are pronounced shadows coming off them which totally ruin the photo.
  • Sony Master
  • 3,287 Answers
This is usually a very simple fix. You may be holding the camera in such a way that one or more of your fingers partially blocks the built-in flash of the camera. When this happens, everyone notices the flash has fired, but they do not know that part of the light was blocked, leaving a part of the photo in the shadows.
Find out if this is the problem by picking up the camera as you might normally do, but while maintaining the same grip - turn it so that you can see where your fingers are in relationship to the flash on the front of the camera. Notice where your fingers naturally land when using the camera and and try to remember to keep fingers away from the flash. You might even let someone else try and see if the shadow is gone in their photos. Look how they hold the camera - notice the location of the flash and where their fingers are.
Please take a moment to rate this replay if you found it helpful - good luck!
Posted on Jul 06, 2010
Testimonial: "Thank you for the solution. I had stopped using the camera indoors out of frustration because of the shadow the people in the picture had around them. I can now get back to enjoying my camera. "
  • Steve Jul 07, 2010
    An additional thought - if your problem is with shadows created by those persons or objects in the picture.. disable the flash and try to shoot in natural light instead. You may have enough light in the room for a satisfactory image. Next, you could either diffuse the light by placing a single ply tissue over the flash - or direct the light upward with a piece of white paper or cardboard. The latter method will reflect the light to the ceiling which in turn bounces it on the subjects from above. You might need to experiment with the size of the paper and angle needed based on the distance the subject is from the camera.
Identify and write down the silent letter/sound in the following words:tombstone;knock;pneumonia;align;would
This is easy. It is the letter that you do not pronounce when you say the word. I guess it is easy for me because I am English and old :>)
tombstone; pronounced toom-stone so the b
knock; pronounced nock so the k
pneumonia; pronounced new-monia so the p
align; pronounced a-line so the g
Jun 21, 2017 | The Office Equipment & Supplies
9p5544c102 Horizontal bow
ok meoff check the convergence circuit. shadow in the picture is defective convergence circuit... replace a new.
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
The color brown in Cheyenne is pronounced how?
http://www.cheyennelanguage.org/words/colors/colors.htm
This will show you how it is spelled as well as let you listen to how the word in pronounced.
Semper Fi,
Z
Jun 04, 2017 | Cars & Trucks
Differential noise
indicates axle bearing failure rather than diff problems
diff failure is indicated by a growling noise on acceleration or deceleration or a constant harmonic hum while driving at a steady speed
from your description of where the noise is most pronounced indicates wheel bearings
Jun 28, 2017 | Toyota Tundra Cars & Trucks
Using the flash puts a shadow on the right side of the face. Seems to show only on faces and only when the flash is used.
Nothing "wrong" with that. All cameras do exactly the same.
The stronger the flash, the more pronounced the shadow is.
One way to reduce it is to step back and zoom on the subject, or if your camera has such feature, reduce the intensity of the flash.
If you need some tips, please Google: How to avoid flash shadows?
Apparently many people have this same problem.
Jun 24, 2011 | Cameras
There is one word in the English language that is always pronounced incorrectly. What is it?
Dec 31, 2010 | Computers & Internet
I have a Nikon D80 (18-135mm). Just bought a couple of Quantaray filters. When I use the circular polarizer filter 67mm) in combination with the skylight 1A (67mm), I'm getting a dark shadow in the upper...
Okay, I think you're seeing the shadow of filter stack. If you put a lot of filters on the lens, you're in effect shrinking the field of view. Do enough of this and you'll lose the corners. Imagine holding a roll of toilet paper in front of the lens so you're seeing just a little round picture through the core. This won't matter at the longer focal lengths because you're only using the center of the image anyway, but it will become more pronounced as the focal length decreases.
The easy solution for now is to remove the skylight when using the polarizer. If you absolutely need to use two or more filters, then consider using larger filters with a step-up ring. You might also want to consider somthing like Cokin filters ( http://cokin.com/ ).
Oct 19, 2010 | Quantaray 52mm Pro Digital Circular...
Indoor photos are yellow.
Your camera is choosing (or you chose) the wrong white balance setting. Try Auto White Balance, and if that doesn't work, try tungsten white balance. You could switch to daylight color bulbs in your lamps.
May 02, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Horizontal bow and shadow
Replace convergence IC's--then re-check convergence alignment in servicer mode,if necessary.
Sep 27, 2007 | Philips 9P5544C 55" Rear Projection...
Sony Cyber-Shot DSC-S40 Digital Camera Logo
137 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
