Question about GE 5.8 Cu. Ft. Extra-Large Capacity Electric Dryer
Gas clothes dryer
Makeing black marks on clothes
    President:
  • 1,430 Answers
This is usually caused by the front bearing glides. They are inexpensive and easy to replace.This video will walk you thru checking and replacing. http://appliancehelponline.com/dryerfrontbearingvideo.html
Posted on Jul 06, 2010
Maytag gas dryer about 10 years old leaving black smudge marks on clothing. The wheel was hanging up on the dryer drum. Could there be other causes for the smudge marks?
your clothes are getting caught between the drum and the rim due to bearings out of the wheel guides. These guides are what the drum rests on when it is turning. Most dryers you can access these guides by taking the front off the dryer. Not a big expense just a little difficult to get to .
Apr 12, 2011 | Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Clothes keep getting stuck by the top of the door leaving a black mark
the black marks are from a bad seal to the door or drum seal. Check that out and replace it if neccessary
Mar 13, 2010 | Amana ALG331RAW Gas Dryer
I have a Maytag Neptune gas dryer and recently light colored clothes are coming out with small black marks on them; it looks like grease/oil stains. Where could this be coming from?
my first guess would be something ,someone placed in dryer perhaps coveralls or oily clothing.There is no place that I am aware of on a dryer where you could pick up oil leaks from ..are you sure you did not have a lint fire,the oil stains may be soot
Dec 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
How to clean black marks left in dryer from shoes
I had used a little nail polish remover on the marks when this happen. Then I wiped it out with a cloth after I was through doing the dishes ( had dish detergent on it) and a rinse cloth and dried. I then always let the shoes/boots air dry or you could put them in a pillow case to dry. Good Luck!
(You should have seen the mess I had with a melted blue crayon one day!) Got that out too-but it took me a while.
Oct 21, 2009 | Whirlpool GGQ8831L Gas Dryer
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Black Marks on Cloths
either the roller are degrading or the belt the black is caused by the grinding of the dryer as it spins and has no cushion left replace the rollers
May 03, 2008 | Maytag MDG2706A Gas Dryer
Mdg4000 GAS
bad rollers could be making black dust but the real problem is the tumblers seals letting the roller dust get into the tumblers and on to you clothes.
Black or brown makers are from the faulty or damaged tumblers seals you have one in the frount and one back...
I can help you strp by step if you want to do it yourself.
Dec 23, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Jul 06, 2007 | LG DLE2514 Electric Dryer
GE 5.8 Cu. Ft. Extra-Large Capacity Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
