Question about Cameras
Windows computer doesn't meet the system requirements as stated on the camera packaging.
  • 3,287 Answers
With the very limited info you've provided, no one will be able to solve your problem very quickly. Please provide the Windows version you are running (whether 32 or 64 bit) and the manufacturer's name and model of the camera if you wish to use the camera and computer as described in the camera's manual. You might be able to work the camera's supplied software in one of Windows' "Compatibility" modes.
If you're willing to forgo trying to get that combination working - you should be able to buy an inexpensive external card reader that connects via USB to your computer - and insert the memory card from your camera into it - instead of trying to transfer pictures directly out from the camera (assuming you are unable to transfer pictures AND the memory is removable). Windows has built-in software with the ability to display JPEG (or JPG) images and can do some minor editing on them. You can also purchase image editing software that can provide a much broader range of edits if desired.
Please rate this reply if you found it helpful - good luck!
Posted on Jul 06, 2010
Can I install a software package over the one on the computer.
It is done all the time. IF the directory is damaged then you would install it in a different directory for example instead of c:\windows you would create a new directory like for example it c:\win7. It is also true for every verson of windows ever made. Good Luck.
Nov 02, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How can I tell if a game will run on this computer?
Check its <span>Windows</span> Experience Index score <p>The <span>Windows</span> Experience Index is a measure of how capable your computer is. To calculate it, <span>Windows</span> analyzes the hardware and software on your PC and then assigns it a score. The higher the number, the more likely your PC can handle games and other demanding programs.<br /> <p>When you buy a game, make sure the minimum score recommended by the publisher (typically printed on the box) is <span>less than, or equal to,</span> the <span>Windows</span> Experience Index for your computer. That's one way to ensure it will run smoothly.<br /> <p><br /> Check its hardware requirements <p>Even if your computer's <span>Windows</span> Experience Index score is good enough for a particular title, it's possible that an individual piece of hardware-a video card, for example-on your PC isn't.<br /> <p>That's why it's also critical to study the <span>minimum system requirements</span> listed on the game packaging and confirm your computer meets or exceeds them. Few programs put a heavier demand on your computer than games. If your computer's specs fall short, a game might run sluggishly-or not at all. <br /> <p>The components game publishers are typically most concerned with are:<br /> <ul> <li> <p><span>Central processing unit (CPU):</span> Make sure both the CPU speed and model meet the game requirements.<br /> </li> <li> <p><span>Random access memory (RAM):</span> Many games now require at least one gigabyte of RAM.<br /> </li> <li> <p><span>Video card:</span> Your video card must have a certain amount of memory and have a compatible <span>chipset</span> (publishers usually list the make and model of compatible cards). Cards must also typically support DirectX 9 or later.<br /> </li> <li> <p><span>Hard disk</span>: Most games require a certain amount of free space.<br /></li></ul>
on Dec 11, 2010 | Computers & Internet
Difficulty to open pdf files
1. Make sure that the system meets the requirements for the Acrobat product that you use.
Acrobat can't run correctly if the system doesn't meet the following requirements:
  • Intel Pentium processor
  • Microsoft Windows XP Professional or Home Edition with Service Pack 1 or 2, or Tablet PC Edition, or Windows 2000 with Service Pack 2
  • 128 MB of RAM (256 MB recommended)
  • 460 MB (Professional) or 360 MB (Standard) of available hard-disk space; optional installation files cache (recommended) requires an additional 300 MB of available hard-disk space.
  • 1024 x 768 (Professional) or 800 x 600 (Standard) screen resolution
  • CD-ROM drive, if installing from a CD
  • Internet Explorer 5.5 or later
Jun 16, 2011 | Adobe Acrobat 7.0 Professional
:Error: the vc8 runtime Redistributable package was not installed successfully. Setup cannot continue
The Microsoft Visual C++ 2005 Redistributable Package (x86) installs runtime components of Visual C++ Libraries required to run applications developed with Visual C++ on a computer that does not have Visual C++ 2005 installed.
This package installs runtime components of C Runtime (CRT), Standard C++, ATL, MFC, OpenMP and MSDIA libraries. For libraries that support side-by-side deployment model (CRT, SCL, ATL, MFC, OpenMP) they are installed into the native assembly cache, also called WinSxS folder, on versions of Windows operating system that support side-by-side assemblies.
System Requirements
  • Supported Operating Systems:Windows 2000 Service Pack 3;Windows 98;Windows 98 Second Edition;Windows ME;Windows Server 2003;Windows XP Service Pack 2
  • Required Software:
  • oWindows Installer 3.0 Windows Installer 3.1 or later is recommended.
  • Disk Space Requirements: 6 MB (x86)
File Name: Size: vcredist_x86.exe 2.6MB Download
Jan 05, 2011 | Sony Computers & Internet
I have purchased two more click and play games and loaded them onto my computer--they state that windows xp is required which i have. The games will not play saying my computer does not support them i have...
In order to play any higher grahpics PC games, you need to have a CPU, graphics card and monitor that meet the games requirement specifications.
Check out the hardware and software requirements first before you purchase any gaming softwares.
Jul 02, 2010 | Computers & Internet
Sir can i install CRYSIS1? my windows is vista basic
Yes you may, but you should meet the recommended system requirements (stated below) to enjoy palying the game.
Crysis1 Recommended Requirements
CPU: Dual-core CPU (Athlon X2/Pentium D)
Graphics: Nvidia 7800GTX/ATI X1800XT (SM 3.0) or DX10 equivalent
RAM: 1.5Gb
HDD: 6GB
Internet: 512k+ (128k+ upstream)
Optical Drive: DVD
Software: DX10 with Windows
Vista kpfrlewajveq0aaaaasuvork5cyii%3d
Nov 05, 2009 | Microsoft Windows Vista Ultimate Edition
Moto gp 08 wont load on my computer. ive downloaded direct x 9 and my video card meets the requirements. what should i do?
Hai, MOTO GP is a nice game, the system requirements for MOTO GP 2008 is given below
System requirements:
  • Operating system Windows XP/Windows Vista;
  • Processor Intel Pentium 4;
  • Operative memory of 512 Mb (Windows XP)/1 Gb (Windows Vista);
  • 5.5 Gb of an empty seat on a hard disk;
  • Video card with support DirectX 9.0c/Shader3.0, NVIDIA GeForce 6600 or is better, ATI Radeon X1600 or it is better;
  • Compatible with DirectX 9.0c a sound card.
Do you meet all these???If any installing Bug Try this!
Aug 05, 2009 | Video Game Consoles & Games
Vista
All info on this site
Requirements here
There are many installation types all are stated in the Menu on the Right hand Side, on the page I stated above.
If I was helpful, kindly Do Rate!
Regards.
Aug 01, 2009 | Microsoft Windows Vista Home Basic Edition...
What are the system requirements of the DiMAGE 5?
System RequirementsIBM PC/AT compatible computer with preinstalled Windows Me, Windows 2000, Windows 98*, or Windows 98 Second Edition* and with a built-in USB port as a standard interface.Power Mac G4 (includes dual processor G4 and G4 Cube) series, G3 (Blue and White) series, iMac series, iBook, or PowerBook G3 with preinstalled Mac OS 8.6** – 9.1 and with a built-in USB port as a standard interface. • Problems may be encountered depending on what other USB devices are being used in parallel with this product. • Only a built-in USB port is supported. Problems may be encountered when the camera is connected to a USB hub. • Normal operation may not be possible even when all the system requirements are met. * Users of the Windows 98 and Windows 98 Second Edition must install dedicated driver software included in the DiMAGE 5 and DiMAGE 5 package. ** Users of the Mac OS 8.6 must download free dedicated driver software from the Apple Computer web site and install it.System requirements are based on the latest information available at the time of printing and are subject to change without notice.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
