Question about Filter Queen Majestic Canister Vacuum
Motor stopped working brushes sparking how do we replace brushes
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Posted on Apr 18, 2008
After my son vacuumed up maybe a lego theDiamond G Kirby started sparking from inside housing. We took brush and checked for any loose items and found none. Any ideas and can I diy?
Sucking up a Lego or similar item normally should not have done any damage to the motor. It may stop the brush roll which may burn the belt if the belt is tight. If the item got sucked into the fan it may have broken or cracked it which could seize the motor. Remove the brush roll assembly, spin the motor shaft while you inspect the fan. Fan replacement is best to be done by an experienced technician.
Jan 24, 2017 | Kirby Vacuums
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
The motor that powers the brush the brush that beats the rug has a sparking in it ( it works but this does not appear good)
you will see sparks all the time around the brushs if it is working and if the sparks do not go all the around the comutaor
it will be fine
Oct 28, 2010 | Fantom Vacums Lighting Canister Vacuum
Sparking motor brushes
Sounds like your motor has had it, its possible to replace the carbon brushes, but probably wont last much longer.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jul 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Sparking motor on Dyson assume motor brushes at fault?
A replacement motor can be purchased direct from Dyson via our Helpline on 0800 298 0298 at a cost of £36.31.
Alternatively we can arrange a service for £69 which includes parts, labour and VAT. This can also be arranged via our Helpline.
Kind regards
Darran
Dyson Customer Service
Mar 02, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
Oct 16, 2009 | Vacuums
Smells like the motor is burning. observing sparks. It the motor cooked and is it just time for a replacement?
If you're observing sparks, then yes, just get a new one. With the low prices of good vaccuums its not worth starting a fire with your vaccuum. If it just smells like the motor is burning, check the belt and make sure its rotating freely and if you have an attachment, make sure the brush on the vaccuum is not being stopped while using the attachment. However, if you are seeing sparks,,,, definately time to junk it
Aug 20, 2009 | Sharp Twin Energy EC-TU2603 Bagged Upright...
Kenmore canister vac model 116. 2641381
Sounds like motor brushes may be going. Is the vacuum cleaner old? I suggest bringing the unit in for service to replace the motor brushes. Get a quote to see if is worthwhile to fix.
Feb 27, 2008 | Kenmore 22812 Bagged Canister Vacuum
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Brush motor failure
Looking at the parts breakdown, the motor must be in the nozzle asm. part # 75213 and sells for about $25.
Dec 01, 2007 | Eureka 421A EZ Kleen Bagless Stick Vacuum
Filter Queen Majestic Canister Vacuum Logo
512 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
