Question about LG Heat cool Window Air Conditioner
Lg n98 remote for aircon what do the settings mean? the water drop and triangle with a squiggle in it . i usually leave it on the sun setting pick a temp and the aircon turns on and off and is very noisy. is there a setting i can use that maintains the temp without the main unit and fan turning off when it reaches temp
How do I set it to heat up the room?
Posted on Jul 21, 2013
  • 400 Answers
SOURCE: Thermastat on LG Split system
The star with a face is sleep mode, each time you press it you will see a 1 then 2 then 3 up to 7 appear in the lower right corner of the screen. This means that the unit will operate for 1 or 2 or 3 hours then switch off. The house with key if pressed will give you the actual room temperature assuming the remote control is in the same room. It will return to setpoint temperature in a couple of seconds. The triangle with face is termed "Chaos mode" The unit will stay on a preset temperature probably 18c but the airflow will vary and the louver will go up and down irratically or randomly, as it tries to immitate a natural breeze. The fan only button will put the unit into fan mode (no compressor driven cooling), the fan icon with circle around is for fan speed which goes up each time it is pressed. Hope this helps.
Posted on Mar 05, 2009
  • 400 Answers
SOURCE: lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Posted on Mar 20, 2009
reddyanantha
  • 205 Answers
SOURCE: LG 24000btu not blowing cold air. Fan runs but i
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Posted on Sep 04, 2009
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
bobicehouse
  • 1524 Answers
You have a clogged drain.
Posted on May 23, 2009
Does not produce Heat
Sounds to me like it is defrosting the outdoor unit. Is this possible? The process takes a little bit to complete but it will then start up again.
Nov 14, 2014 | LG LA120HYV Art Cool 120HYV Ultra...
What do the symbols on the display mean and which one does the cooling operate better on . model number kyd-32a thanks
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Dec 31, 2010 | Heating & Cooling
What is the button to heat up my room?
Open the cover on the remote, to the top left (usually) there is a single button which if pressed repeatedly, changes the mode settings. This can also be seen by changing icons on the display. The first is an ice crystal, second tear drop, third a triangle with a moon, fourth is a sun. Press until you have the sun icon in the display area. Then close the remote and using the up arrow and down arrow buttons select the temperature which is comfortable for you.
Nov 17, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Cant feel heat using remote 6711A10010D
You need to ensure that the LCD displays a sun symbol. If this is not the case this can be corrected by using the button which has triangle, snowflake, sun and raindrop symbol, press until sun is on screen. Then set temperature.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 08, 2009 | LG LSC121PMA Split System Air Conditioner
Cant make it blow out hot air.
You do not mention the model. Most aircon remotes have a mode button which has three or four icons. On cooling there will be a ice crystal icon on the lcd display. Pressing the mode button (sometimes behind a cover on the remote) this icon will change. You want to set it to the "sun" shaped icon
Jun 02, 2009 | LG Heating & Cooling
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
Mitsubishi A/c remote control has no instruction manual
That is the mode setting.
The triangle is "I feel" mode. You adjust up or down according to how you feel
The star is "cool mode"
The wind or fan shape is for the "fan on/off" mode
And the rain drop is the "dry" mode to lower the humidity in the house.
Jan 24, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Lg airconditoner remote contol n98
Open the front grill of the indoor unit. Check on right hand side for a forced operation switch. This switch is for selecting of either manual operation or remote or auto, select remote, then try. You can also press the reset button on the remote, under the cover with a pen. Hope this helps
Oct 09, 2007 | Network Computing Devices NC900 Network...
LG Heat cool Window Air Conditioner Logo
1,751 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
