The copies on the fax are too dark. How to lighten them. Brother 8070P
leroyal
  • 2120 Answers
SOURCE: BROTHER 8070P
leave the door open and hold down the clear button.
Posted on Nov 25, 2008
leroyal
  • 2120 Answers
SOURCE: when i make a copy on my brother 4750e i get the plain black copy
Your scanner block has a loose connection or it is bad.
Posted on Nov 26, 2008
  • 215 Answers
SOURCE: On my Brother MFC 4800 LASER plain paper
yes indeed. i'm sure by your symptoms, thats what it would be.
Posted on Mar 30, 2009
lbrown1806
  • 488 Answers
SOURCE: eroor 77 for fax brother
Open the front panel, remove the toner cartridge and close the panel. The printer tries
to warm up and then it will say to open the panel door. Open the door, insert the toner,
close it and the machine error will be cleared.
Posted on Jan 15, 2011
  • 159 Answers
SOURCE: Brother FAX-8070P memory shows full
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Posted on Jun 06, 2011
Testimonial: "Excellent service, problem solved. Thanks "
Eroor 77 for fax brother 8070p
Jan 15, 2011 | Brother FAX-8070P Plain Paper Laser
We can send a fax and although there is no phone attached it rings but we are not receiving faxes even though we know they are being sent to us
You are set for MANUAL RECEIVE, when the fax rings, press the START button to receive a fax.
Check the MENUS for AUTO RECEIVE settings.
Nov 25, 2009 | Brother FAX-8070P Plain Paper Laser
Faxing copies of drivers' licneces result in poor quality
The Brother 2800 is pretty good machine within its limitations.I would suggest if possible to copy the drivers license on a regular copier and both lighten it up and enlarge it.I had good results using this procedure when I had to fax Licenses.Good Luck
Mar 25, 2009 | Brother IntelliFAX 2800 Laser Fax
Changed drum and need to reset the counter
Leave door open and press clear/back button. Press 1 for yes -new drum or 2 for no-new drum. Close door and you are finished. Hope this helped.
Mar 13, 2009 | Brother FAX-8070P Plain Paper Laser
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Dark papers
are you using brother products or generic. using some generic supplies will cause this problem
Jan 14, 2009 | Brother FAX-8070P Plain Paper Laser
BROTHER 8070P
Nov 24, 2008 | Brother FAX-8070P Plain Paper Laser
Can you tell me where I can obtain instructions for a brother fax machine 8070p lazer please
www.brother.com
choose your country and your mfc/dcp.
download the instructions (manuals + faq) needed.
Apr 23, 2008 | Office Equipment & Supplies
Trouble sending fax from 1 machine when 2 fax machines are on the same line.
I am not an expert but I would suggest to simply diconnect the other one when sending cheeeeeeeeers
Feb 13, 2007 | Brother FAX-8070P Plain Paper Laser
516 people viewed this question
jasbo
jasbo
