Question about Hoover HCA390FFK Bottom Freezer Refrigerator
Hoover fridge freezer is freezing food and drinks in the fridge
I have been told I need a new controller, how do I get the front panel off to replace the controller, I can't see any screws so I'm guessing I prise it of with a screwdriver.
Hoover hnmf4507 a-80 is not frost free
Posted on Jul 29, 2010
I have a Hoover Fridge freezer and my fridge is really warm inside and the freezer is not freezing the food in the top drawer but it is keeping the food a bit cold. What could be wrong with it?
It could be
- a faulty thermostat
- a loss of refrigerant through leakage
- a very poor sealing door gasket
If the fridge is old I'd say you will need to replace it.
Nov 13, 2016 | Hoover Refrigerators
TOP HALF OF FRIDGE COVERED IN ICE AND FREEZING FOOD/DRINK
I have had this problem in the past. You will need to get the automatic defroster fixed or take all products out of freezer part of fridge. Remove back panel of freezer unplug from wall let defrost. put fan in front of it to speed proses. usually an hour or so depending on how badly frozen it is. good luck.
Apr 10, 2013 | Refrigerators
THE FRIDGE PART OF MY FRIDGE FREEZER ,FREEZES ITS CONTENTS.IT IS A HOOVER FRIDGE FREEZER MODEL NO.HNMF2805A-80
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 26, 2011 | Hoover Refrigerators
Hi. The fridge part of my fridge freezer model HNMF2805AL80 is freezing my food , it is set at its lowest setting
My HNMF2805AL80 did same. Replaced control moduile - still freezing. Have just replaced fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just put sensor inside fridge at back - so far so good, will let you know.
Nov 24, 2010 | Hoover Refrigerators
HOOVER CLASS A FROSTFREE FREEZE HNMF 2805A L-80 FREEZER IS WORKING BUT FRIDGE INSIDE IS COVERED WITH SHEET OF ICE AND BLOCK OF ICE AT BACK FOOD AND LIQUIDS ARE FREEZING HAVE ALREADY TRIED TURNING DOWN...
I had same problem. Needed a new thermostat. Lasted about 18 months, then needed to replace fridge. Ice build up is between the inside and outside layers of the fridge as well. May just be more economical to replace. Cheers
Oct 26, 2010 | Hoover HCA331FFK
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
We have a Hoover No frost refrigerator/freezer. There is no control for the fridge temperature which is now running very cold (it freezes drinks, etc.). What can I do to increase the temperature of the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | Hoover HCA391FFK Bottom Freezer...
My fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
Fridge is freezing food
I have had the same issue with thick frost/ice at the back of my Fridge and almost called an engineer and considered replacing it.. BUT you don't want to so that: Do this:
1. Take freezer draws out and empty fridge so it is lighter and easier to move Fridge Freezer out
2. Chuck some warm soapy water down the drainage hole in back of fridge to ensure it is not blocked
3. Pull the plug. Leave it off for 5-10 mins.
4. Plug it in, reload her
5. Next morning.. perfect all back to normal
I think the unplugging just resets the thermostat and gets your machine back to life.
Jan 13, 2010 | Hoover Refrigerators
The fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Jan 05, 2009 | Hoover HCA390FFK Bottom Freezer...
Hoover HCA390FFK Bottom Freezer Refrigerator Logo
403 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
