Question about Xerox CopyCentre C128 Black and White Copier
Photo copier c128 balck& white
Error code 062 380
  • Anonymous Apr 22, 2008
    yes sir
    i don't know how find tha calabrtion?
    send me reply as soon as possible
    thanku
    your's lovingly
    babu
How to do calabrtion???????????????
Posted on Apr 23, 2008
HOW TO FIND CALABRTION COULD YOU PLEASE GIVE ME
FULL DETAILS PLEASE
Posted on Apr 22, 2008
    President:
  • 2,072 Answers
That is an issue with the scanner.
1. When you turn the machine on, with the document feeder do you see the lamp coming on?
2. Shut the machine off and disconnect the cables from the scanner and document feeder, reconnect them and turn it back on.
If that is not it, A service call is the best thing to do, it is a calabration error in the scanner.
photo copier c128 balck& white - arrwup.gifDescription At the adjustment of CCD output after power on, CCD does not make a correct output which it should when it receives a specified amount of light.
arrwup.gifInitial Action
  • Refer to BSD 6.3.
  • Power OFF/ON
  • Procedure Check the lamp, lens, mirror and the white correcting plate for abnormalities such as contamination and deterioration.
    Abnormality such as contamination or deterioration of the lamp, lens, mirror or the white correcting plate is found.
Posted on Apr 18, 2008
Xerox 4595 error code 062-380
Platen AOC Failure.
Power off completely and then power back on.
If the problem persists please Call for Service.
Jul 12, 2014 | Xerox CopyCentre C128 Black and White...
Msir machine show error code of 010-327. plese tell me error solu.
The fuser is not warming up properly. Could have paper wrapped around it, but most likely the over heat popped. You will most likely need to replace the fuser.
Jun 03, 2011 | Xerox CopyCentre C128 Black and White...
How do I do a password for the machine Xerox CopyCentre C128
Click on the link below and select to view the Xerox CopyCentre C128 owners manualm inside the manual will show you how to set the password
http://www.support.xerox.com/support/copycentre-c123-c128/documentation/enus.html
Dec 19, 2010 | Xerox CopyCentre C128 Black and White...
Error 010-327 workcentre 5230
machine show error code of 010-327. how to correct this error
Oct 05, 2010 | Xerox CopyCentre C128 Black and White...
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
Error code 027-452 Please see user guide Pl provide a solution
A PC with the same IP address exists on the network.
arrwup.gif Procedure Inform the customer that the IP address of the machine is the same as the IP address of another machine on the network.
Jul 17, 2010 | Xerox CopyCentre C128 Black and White...
Fault code of 062-380, the copier won't do anything
That is a fault code of the scanner CCD. It is not detecting enough light.
First thing I would ask is when you turn the machine on do you see the lamp come on? When the machine powers on, it will turn on the lamp and look at the white reference strip on the bottom side of the glass.
If it is not coming on the lamp may be bad. If the glass it very dirty and that white strip is dirty you will get that code.
But here are the 3 suspects.
Replace the lamp, lens, mirror or the white correcting plate.
Mar 17, 2010 | Xerox CopyCentre C128 Black and White...
Xerox CopyCentre C128 Black and White Copier Logo
874 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
