Cant reboot my acer 5050 aspire LAPTOP - Computers & Internet
  • 3 more comments
  • sweetneszz Apr 22, 2008
    no i dont know how to go about rebooting it, i need instructions please
  • sweetneszz Apr 24, 2008
    just need intruction how to reboot my acer aspire 5050, cause there is a warning saying to reboot it, so i want to reboot it to its factory settings,but i dont have the disk, so i need instructions how to do so
  • Anonymous Dec 13, 2008
    Hi
    My ACER PC
    When i turn it on it says
    A disk read error occurred
    Press Ctrl+alt+del to restart
    Can you help me
    what do i do??????
  • Anonymous Jan 23, 2009
    i dont have a disk to restart my computer
LOL @ the above post!! Restoring factory settings is not at all that complicated, as long as the person attempting it is somewhat Windows savvy. You do not have to attend college to restore or reinstall an operating system. Knowing your way around your OS and an understanding of device drivers is all that is required.
Posted on Dec 09, 2009
    Novelist:
  • 150 Answers
Do you mean it's running and you cannot reset it,
or is it dead and it won't boot?
If so, is it dead dead, or does it boot part way ?
Posted on Apr 18, 2008
  • Martin J Stadler
    Martin J Stadler Apr 22, 2008
    From windows:
    1) Click: Start ---> Turn off computer --> Restart
    or
    2) Press Control-Alt-Delete (all three keys at once)
    to bring up the task manager, and then click
    on the shut down menu
    or
    3) Press and hold the POWER button for several seconds
    until the PC shuts down. It will eventually.
    Please note that option 3 will not allow any active applications
    to shut down properly and save open files. Also, any pending
    hard-drive write back cycles will not get written, causing the
    risk of data loss.
    Windows may also report an improperly shut-down hard drive
    the next time it re-boots, just be patient and let windows fix it.
    Option (3) should only be used when the computer is totally
    crashed/frozen and no other method is possible.
    Martin
  • Martin J Stadler
    Martin J Stadler Apr 25, 2008
    Hi, just to alleviate your confusion:
    There is a BIG difference between "re-booting" and
    "returning to factory settings"
    1) Re-booting simply means to re-start the machine,
    with the latest settings in tack. This is sometimes
    required when you install a new program or device
    driver such that the new program needs to replace
    files or settings that are protected by windows.
    By rebooting the machine you re-initialize memory
    and re-start Windows, giving the installing program
    a chance to finish its installation BEFORE windows
    security comes up.
    This is NORMAL behavior when installing programs.
    2) Another reason to re-boot (restart) the machine, is
    when and application program crashes due to poor
    programming, causing windows to malfunction or
    freeze.
    This is what you do to get out of trouble.
    There are two kinds of reboot: Soft or Hard reboot.
    3) Soft Reboot: is like asking windows to re-start itself:
    During soft reboot, windows will orderly shut down all
    programs, save all data to disk, finalize all disk transfers,
    and then re-load itself.
    Soft reboot is the preferred method, because all data is
    saved and there is no corruption of the hard-drive index
    structures (as in directories and file allocation tables)
    To perform a soft Reboot:
    a) Hit the ESC key to abort and close any open
    Pop-up messages and windows.
    b) Close all programs by clicking on the "X" in the top
    right corner of each window. Save files if necessary.
    c) Click on START, "Turn off Computer'
    d) Chose re-start
    (This assumes that you are running windows XP,
    the menus may be a little different for VISTA
    but the action is the same)
    e) Another way to do a SOFT reboot is to press:
    Control-Alternate-Delete (CTRL-ALT-DEL)
    at the same time.
    i.e. use 3 fingers and simultaneously press the
    three keys on the keyboard.
    This will bring up the task manager, which has
    a shut-down menu command.
    4) Hard re-boot is a measure of last resort, because
    data is not saved, hard disk transactions are not
    finalized and the disk index structures may be
    corrupted upon re-start.
    While this is not desirable, it is not as terrible as it
    sounds because Windows is able to recover and
    automatically repair the damage in most cases by
    scanning and repairing the disk index structure
    when it starts-up again. Just be patient, and let it
    do its thing.
    Hard reboot is ONLY indicated when the machine
    crashes, refuses to do a soft-reboot, or freezes
    and won't respond to any of your commands !
    To do a HARD reboot on a DESKTOP you hit the
    reset button on the main box
    On a laptop, you press and hold the power button
    until the machine shuts off. Then you turn it ON again.
    Pressing CTRL-ALT-DEL, all three keys at once will
    also HARD re-boot the machine during the early stages
    of system start-up, before Windows is loaded.
    Doing the same from Windows will launch the program
    manager as described above.
    5) Restoring the machine to factory settings involves
    erasing the hard drive and re-installing windows.
    YOU DON'T WANT TO DO THIS !!!!!
    This is an involved process that should be only done
    by someone who knows what they are doing.
    Re-installing everything is a destructive process,
    causing the loss of all updates, settings,
    application programs and sometimes user data,
    such that everything has to be re-installed,
    taking anywhere from days to months.
    This is only indicated when the operating system
    (Windows) has been hopelessly corrupted or infected
    by viruses that cannot be removed by other means.
    To re-install the system on a desktop requires (many)
    setup disks, skill and tons of time.
    To revert a laptop to factory conditions can often be done
    by activating the "restore" sequence from a hidden back-up
    partition on the hard drive, by pressing a special key
    (or key sequence) at the right time during system start-up.
    This process takes several hours, and you loose absolutely
    everything you have done since you bought the PC, including
    all OS updates and added device drivers.
    This is the ATOM BOMB approach to fixing your computer.
    Finally your computer is not a toaster or a calculator that you
    can simple re-set. It is a complex device which contains
    thousands of programs systematically installed in layers
    and configured for your needs.
    Some times the computer needs to be re-started with a
    SOFT reboot or perhaps a HARD reboot.
    Re-installing everything is not something you want to even
    remotely get involved with. Its like re-building your engine
    on your car.
    Martin
The cooling fan in my Acer Aspire laptop (bought 1 year ago) stopped working. Can it be replaced or is it part of the motherboard?
As stated it can be replaced. Might be the pits in finding the replacement fan, though.
Let's take a look at an Acer Aspire 5520 series laptop, as an example,
http://www.insidemylaptop.com/take-apart-acer-aspire-5520-laptop/
Scroll down until you come to the third photo.
Getting to the Cooling Fan in the Acer Aspire 5050 series Notebook PC's, requires a lot more disassembly, however.
The Acer Aspire 5050-3242 Notebook PC, in the category heading, is part of the Acer Aspire 5050 series of Notebook PC's.
This is the Service Manual for the Acer Aspire 5050 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the second Aspire heading.
The one that begins with Aspire 1200.
Now go down to the 5th line, and scroll across to > 5050.
Left-click on 5050.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
[ Although I would recommend upgrading to Adobe Reader 9, if it isn't on your computer ]
After you click on the file > 5050, you won't see anything happening for up to 30 seconds.
Most of the time the first page pops up within 10 seconds, and it requires additional time to fully download the file.
Suggest you let the file download all the way, before looking through it.
Watch the Download Progress bar.
You can save this file to your computer.
This way you can burn a copy to CD for safekeeping, and easy access anytime you wish.
You can also delete from your computer then, to save Harddrive space.
If you do not know how, and wish to, simply post in a Comment.
For further questions on this please post in a Comment.
Regards,
joecoolvette
Nov 10, 2010 | Acer Aspire 5050-3242 Notebook
Download drivers for acer aspire 5050-5430
Please try the following sites for yourr requirement:
www.support.acer.com
www.driverstock.com/???Acer-Aspire-5050-driver-download/4-21-12863/???index.html
Sep 16, 2010 | Acer Aspire 5050 5430 Laptop
Reboot system
my acer aspire is hang insert battery time,ac put normal work,my modle is acer aspire 5051anwxmi
Mar 29, 2010 | Acer Aspire 5050 5430 Laptop
Cant switch on wireless lan acer aspire 5050
first u check in device manager under hardware there was option is there network controller that having device name wireless adapter.
Dec 27, 2009 | Acer Aspire 5050 5430 Laptop
Web cam acer aspire 5050
find here
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Acer-Aspire-5050-Webcam-Driver.shtml
u can go with these links
Jun 12, 2009 | Acer Aspire 5610-4648 Notebook
Wireless capabilities turned off on my acer aspire 8930
Hi,sorry for my english,i'm a italian user.
I had the same problem.
try to uninstall and reinstall the wireless card driver and reboot system,it should work......let me know if works........bye..
Apr 08, 2009 | Acer Aspire 5050-3242 Notebook
Acer aspire 5050 is havin problm
google "acer aspire 5050 webcam drivers"
click a site, download ,then install
Aug 24, 2008 | Acer Aspire 5050-3242 Notebook
Reboot to its factory settings
do you mean reload the operating system ?
if yes and if you didn't delete the recovery partition in your harddrive, you can press alt+f10 during boot, it will guide you to the reload operating system.
Apr 24, 2008 | Acer Aspire 5050-3242 Notebook
Cannot reboot
reboot means is to restart again your computer, if the laptop cannot reboot then maybe got and error to your system.
and if cannot be shutdown, just long press, the power button until it shutdown, donot dehydrate or discharge the laptop battery , may damage the battery.
If the computer system experience this maybe you have to reinstall the windows correct the current error.
may this help, melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 18, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
746 people viewed this question
David Payne
David Payne
