Question about Kenwood XD-A55 CD Shelf System
Kenwood Allora XJ7M
No Audio but have power.. 4 pcs. audio equipment
try to change the amplifier transistor D2250. But no luck at all. Pls help TY in Advance....
5 Suggested Answers
SOURCE: Kenwood audio equipment
there worth from 35 to 80$ per speaker ! plus the box. I've got the same ones 2x10 in a box and never had a problem. If I did it was always with the power amp settings. Remember the speaker specs when setting up the amp. otherwise sell them quick on ebay or your local cash converter shop.
Posted on Feb 24, 2008
dunnbiker
  • 8546 Answers
SOURCE: how to connect my kenwood vr-606 digital audio to
Your TV is NOT an audio source by itself. It's job is to make pretty visual stimulus for your eyes, not your ears. Everything IT hears comes from somewhere else like a DVD, BluRay, Cable Box, right?
Get the absolute best TV-related audio directly from the digital audio outputs of each source you're watching, not the TV.
Posted on Feb 20, 2010
SOURCE: Pls tell me the code for DPX8070MJ audio setup.thnk u
I unblocked my DPX-8070mj radio. check it out on www.technologz.com or this link http://bit.ly/g5bYGf
Posted on Dec 07, 2010
SOURCE: how should i have my
On the outputs of the amp there is:
1 2 3 4
terminals. Internally in the amp the positives (1 and 2) are connected together and negatives (3 and 4) together. So there is no difference between hooking up in any of the configurations 13, 14, 23 or 2->4. If its a matter of style, probably use the 14 set, since they're furter apart and harder to short out that way, but electrically it doesn't matter.
Posted on Mar 17, 2011
SOURCE: Hi. I have a kenwood
you will need to ajust the variable resistor its at the rear next the ptt switch
Posted on Mar 30, 2011
KONZERT AV-502A KARAOKE AMPLIFIER,POOR AUDIO,2-RESISTOR WORN OUT PLS. HELP ME
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
Jan 06, 2013 | Car Audio & Video
Power keeps cutting in and out
Sounds like u have some blown output transistors possibly. Check all connections especially Ground! If no luck have ur local repair technician have a look at it.
Feb 04, 2011 | Kenwood KAC-9103D Car Audio Amplifier
Stuck in protection mode tried everything voltage good wires good ground good open/close button dosen,t help me at all love amp please help
everything you've tryed is useless(with respect) because amp has shorted output transistors one or more and amp is in protection mode to protect your amp from further damage.take it to repair shop or try to locate blown transistor yourself.good luck
Dec 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
My red light is blinking and the screen says E-03 and i am not sure what it means
Red lights and error codes usually mean a fault ha occurred. Usually blown output transistors or input power supply caps are to blame. Don't try to fix unless you are comfortable with doing that and have the equipment. Also try emailing Kenwood tech support, they will be happy to tell you exactly what the error code is and possibly why it is happening.
Dec 04, 2009 | Kenwood Excelon KAC-X521 Car Audio...
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Powers up- and turns off!
If they go in to protection mode the audio amplifiers IC's are damaged and you gotta to change him.Good luck
May 23, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Kac-8404 100w amp
What are the numbers on the transistors?
Jan 06, 2008 | Kenwood KAC-8401 Car Audio Amplifier
No Audio From Amplifier
I would first check for "rail votage" at the rectifiers... If all of your audio transistors are not getting around 40 volts then check the transistors you replaced. They should be getting a 5 volt (10 volt square wave is checked with a scope) "drive" signal. If half of your power supply transistors are not getting a drive signal then replace the kia494/tl494/kia594/tl594---whatever it is. thats the ic chip that supplies the "drive" signal to the power supply transistors. Also follow the board closely out of the power supply transistor to the 494 chip.. there should be some small driver transistors in between.. make sure they are not shorted or fried as well... let me knoe if you need more help
Aug 17, 2007 | Legacy Audio LA720 Car Audio Amplifier
Speaker outputs blown on 4 channel amp
the outputs should be replaced in pairs, there are 2 to 4 pairs, but you sould only need 1 pair replaced. these transistors typically range between 10 to 30 cdn each + labour, look for 1 to 1.5h to replace & test the unit after repair. check your local repair shop for their rates. good luck
Nov 05, 2006 | Kenwood KAC-728S Car Audio Amplifier
Kenwood XD-A55 CD Shelf System Logo
140 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Eddie Dalton
Eddie Dalton
Level 1 Expert
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
