Question about LG 42PX5D 42 in. Plasma HDTV
Xstudio will not work.
When a card is inserted into the appropiate slot and the Xstudio button is pressed I get no response.This has worked several times in the past.The remote control will turn the TV on and off.The card fits in properly and viewing the slot there are no contacts displaced.
SOURCE: LG 37LC7D remote doesn't work
Turns out there is a problem with certain LG models made in Mexico during May. Not only did the remote stop working, but the TV started shutting itself on and off randomly. Took it back and exchanged it for a Panasonic. Not putting up with that, LG.
Posted on Sep 24, 2007
  • 109 Answers
SOURCE: MY LG 37LC7D IS OUT OF CONTROL,TURNS ON BUT NOT RESPOND TO ANY COMMAND,TURNS OF SUDDENLY,WHICH BOAR COULD BE?
the problem is the power supply board. we are an lg servicer. your welcome
Posted on Apr 03, 2008
jerryg50
  • 1689 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 14 Answers
SOURCE: LG 32LB9D LCD TV Remote control doesn't work.
i got one like that same prob ,,,the AGF33694 BOARD NO GOOD DEFECT when warm cot $300.00 i,m stuck with it
Posted on Feb 28, 2010
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
The on and off button won,t work but you can turn it on by theplay button on back of camera
may be dust in the ON/OFF button use CRC cleaner spray around the button, press/release several times switch will work
Nov 14, 2015 | Samsung ST72 Red Digital Camera 16.2 MP,...
Can't remove memory card from printer
hi
  • Ensure the MP970 is connected to a working electrical outlet. Turn the printer on by pressing and releasing the power button located on the upper left hand side of the control panel.
  • Step 2 Select the memory card you wish to use. Insert the memory card into an appropriate adapter if it requires one. Open the Card Slot Cover, located on the right hand side of the printer, by pulling the door out and toward the center of the printer.
  • Step 3 Insert the memory card into the appropriate card slot with the label side facing up. Confirm the Access Lamp is lighted. Close the card slot cover.
  • Step 4 Check the "Select and Print" option on the display screen. Select the "Okay" option.
  • Step 5 Load your preferred print media into the printer. Confirm Paper Source, Paper Size and Media type. Select the "Okay" option. Select the "Next" option. Select the "Okay" option to access the images on your memory card.
  • Step 6 Press the Left or Right Arrow buttons to select the image you wish to print. Press the + or – button to determine the number of copies of this image you wish to print. Select the "Okay" option.
  • Step 7 Confirm your print instructions. Select the Print option to being printing your photos.
  • Jul 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    I insert a sd/mmc card in the slotwhich is same as
    Sounds like the drivers might be missing which is why there is no response.
    Depending on which operating system your running on the laptop will determine what file you download.
    Go to this page:
    http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=VOS_N_1500&os=WLH&osl=en&catid=&impid=
    Choose your operating system, either XP or Vista and then under where it says chipset choose Ricoh Driver and download now. choose download by internet browser. Save it to the desktop if possible and then run the file so it installs.
    If you go thru installing the drivrr and the card is still not being read by the laptop then the motherboard is bad.
    Aug 22, 2009 | Dell Vostro 1500 Notebook
    What does no card mean? Thank you.
    "No card" means that either
    1. You have not inserted a memory card
    2. The memory card is not formatted, or
    3. The memory card is damaged and therefore can't be read by the camera.
    How to insert the memory card:
    1. Open the camera’s battery door by sliding it downwards.
    2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
    3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
    Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
    Before you can use the card, it has to be formatted:
    1. Insert the memory card into your camera as described above.
    2. Turn the camera on by pressing the power button.
    3. Use the multi-select button to select the "SET" option.
    4. Press the right arrow button to set "System" then press down key to select "Format".
    5. The default option is ‘Format’. Select this option by pressing the OK button.
    6. Select "Yes" to format the card.
    If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
    Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
    My Sansa Express freezes and stuck with connected and shows as transfering from computer to Sansa. I pressed the power button and held it for a while but no response. Please help
    First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work for you.
    Jul 10, 2009 | SanDisk Sansa MP3 Player
    SCI Phone i9++
    This things happens to me the.. Check the sim if inserted correctly. If you use sim 2 card slot (bottom slot), the metal connector of sim should face up. When you make a call, be sure you press the sim2 call(P2).
    If you use the sim 1 card slot (top slot), insert the sim in facedown manner. When you make a call, be sure you press the correct button for sim 1 (P1)
    Jun 20, 2009 | Dual Electronics CECT P168 Cellular Phone
    HP C5180 All-in-one : Memory Card Error, No memory card in it
    1. Remove the memory card from the camera.
    2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
      NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
    3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
    4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
    5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
    6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
    Step two: Print the photo
    1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
    2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
    3. When the photo number you want to print appears, press OK .
    4. After selecting the photos, press Photo Menu again.
    5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
    6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
    7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
    8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
    9. Make any other appropriate changes to the settings, and then press Print Photos .
    May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    My sansa will not load to the main screen and i have tried to fix it even when i plug it in to computer i goes to same screen
    First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
    Mar 22, 2009 | SanDisk Sansa MP3 Player
    Loading paper
    Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
    Mar 28, 2007 | Canon P23-DH Calculator
    LG 42PX5D 42 in. Plasma HDTV Logo
    177 people viewed this question
    Computer Repairing
    Computer Repairing
