Sa-dv250 with fault code f61 causing it to shut down to standby immediately?
  • 1 more comment
  • sean jenkinson Apr 18, 2008
    its a technics sa-dv250..... its the amplifier part of a technics 5dvd, cassette, tuner hi fi system
  • sean jenkinson Apr 19, 2008
    still looking for a solution..... have a technics sa-dv250 amplifier( part of a 5dvd, cassette and tuner separates hi fi system) which comes up with F61 in the display when switched on and then switches straight to standby.
    thanks for all comments.... and yes i am familiar with electronics etc.... have my own one man repair business that i have been runing since 1993... just not come across this particular error code and could find no details in the usual places.... will check out all suggestions on monday and post my results.....regards to all... sean
    Brigadier General:
  • 6,966 Answers
Hi seanjenks,
and with the indulgence of the others...
To my understanding error code F61 is a "General Protection" used by Panasonic (and Technics). The general protection can actually refer to several things:
1. Power supply (as the others have indicated). This may be a defective regulator IC, a fault sensor transistor (over current) or even the fan simply not turning (which could be corrected with a can of compressed air and some lubrication);
2. Amplifier section - which could be the power pack IC or again simply some of its terminals/pins are no longer soldered properly to the PCB (printed circuit board). It is also possible that some of the connectors, terminals or other soldered joints are also just loose.
Perhaps what you can do is to isolate the supply to each of the components/sections and determine if the problem is caused by the load/consumer or by the power supply itself. Of course the logic board must still be connected for the display to function.
The above of course hinges on the assumption that you are familiar with electronic components and circuitry, the use of a DVM and a soldering iron. It would be of great help if you have access to a service manual or at least a schematic diagram with voltage readings. Should you not be comfortable with a DIY, then perhaps you need to seek the services of a qualified professional.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 19, 2008
  • 652 Answers
F61 means 'power fault'
  • Unpluge the main power supply.
  • Then pluge it again and try. Also check the connection is good.
If no result on obove then:
  • Check out either audio power amp ic (IC 501) or power supply ic IC 502.
Thanks
Iqbal
    Guru:
  • 1,894 Answers
You can't do much with this the AMP is dead. you need to replace it. it could cost alot.
else it can be like this
Generally a fault with either audio power amp ic (IC 501) or power supply ic IC 502.
As both said ICs get very got first remove bottom steel grill and with the power off and capacitors drained (shorted together with a low ohms resistor or leave unit powered down for a few hours) resolder the ICs legs if there are any signs of cracks aka dry solder joints.
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • Maanita Chadha
    Maanita Chadha Apr 19, 2008
    push the button on the stereo that says demo above it and hole this button in. unplug the power cable leave it unplugged then try to push the power button on the amp for 30 second without connecting the power source after that reconnect the power cable and see issue will be resolved.
  • Maanita Chadha
    you can refer to service manual too but you have to pay for it
    http://www.service-docs.com/store/catalo...
    President:
  • 1,944 Answers
Could you please tell what brand is your receiver?
Posted on Apr 18, 2008
  • Damen Wong
    Damen Wong Apr 18, 2008
    It generally means power fault.
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
On my 5 disc changer panasonic SA-PT950 there is a error displaying F61 then automatically shuts down. How can I reslove this issue?
F61 indicates a fault with the laser and the only solution is to replace it.
I've had a look at my usual supplier and can't find any reference to a replacement being available and on most occasions when they are available it isn't cost effective.
Jun 21, 2011 | Audio Players & Recorders
The song is playing and running suddenly the song stops and the error msg when i restart my dvd. The error msg is F61 displays in Dvd's display. Please give a rply.
Hi ahamedfaisal,
Does F61 appear after a minute of playing or shuts down immediately after you power on the unit?
Jdvillanueva
Mar 16, 2011 | Panasonic Audio Players & Recorders
My panasonic sa ht930 volume when you give me presents on the screen and I f6 1 off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 18, 2011 | Panasonic sa-ht930 Home Theater Audio...
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
I WHAT IS FULT OF F61 IN SA-AK177
HELLO
F61 means a protection code which normally means there is a fault with the audio output IC. Check all your cables for shorts etc, and try hooking it back up. If the error is still there you'll have to put it in for service.
ALL THE BEST!
Sep 01, 2009 | Panasonic Audio Players & Recorders
I have a f61 fault code on my sa-ak600 panasonic audio system
Replace IC500 on power circuit board.
The board at the bottom with heat sink.
STK470-090 voltage regulator Sanyo original.
Dec 22, 2008 | Panasonic SC-AK300 CD Shelf System
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
Oct 09, 2007 | Sony MHC-G100 Shelf System
536 people viewed this question
 Grubhead
Grubhead
