Question about Kenmore 57029 Side by Side Refrigerator
Freezer side not cooling motor running air is blowing
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 06, 2010
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
How to check fan motor funtionality of PFCS1NJXB SS?
It probably has two fan motors. One that keeps the compressor cool and one in the freezer compartment that blows cold air out into the freezer and into the frig. You should be able to hear the motor running and feel the air coming out the vents when you open the door of the freezer. The fan runs all the time. If you do not feel or hear, the fan is not working. The one on the compressor, take the cover off the back and you can see if the fan is turning. It runs all the time also.
May 06, 2014 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Just replaced mother board on Ge gsl25jfpabs to fix problem with cooling and running constantly. still not cooling but we can hear motor and fan running. no cold air blowing into fridge section. wh
NEED TO MAKE SURE FRESH FOOD DOOR IS HITTING LIGHT SWITCH TO OFF POSITION IF NOT NEED TO ADJUST DOOR UP ASSUMING THE FREEZER SIDE IS WORKING OK
If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
Jan 17, 2013 | GE GSL25JFPBS Side by Side Refrigerator
The motor is running, but the freezer is just cool and the ref. is warm. Some osf the lights are on and some are not.
The cooling coils for both the freezer and fresh food sections takes place in the freezer behind the panel. The fan in the freezer blows the air throughout the freezer and into the fresh food side.
First check to make sure the fan is running inside the freezer, you will be able to hear it when you open the freezer door. Then check to make sure the fan on the outside is running. You can tell by pulling off the grille on the bottom front of the refrigerator and feeling air come out on the left side, it should be warm air and not too hot.
If these are okay then look in the freezer behind the food and shelves. Near the bottom of the freezer look for a frost build up on the back panel. If there is a frost build up then you have a defrost problem. If you see a little frost on the panel that means there is a lot behind the panel that is blocking the cool air from flowing.
Let me know what you see and I will help you from there.
Phil
Jun 21, 2010 | KitchenAid Refrigerators
Frig side does not cool. freezer side cools
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Main food compartment not cooling
you need to replace the fan motor as it blows the cold air to the reefer section and that's why its not cooling the freezers cool both side in all units here's a diag and parts list http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=1TlpO2RMjv7jqHUYRtODnQ**.shcapp3005?modelNumber=596.69272991&pop=flush
May 24, 2008 | Refrigerators
Refrigerator cools, but no freezer fan & no condensor fan running
Check the back of you fridge and make sure the coils are clean. If you have access to a small air compressor, blow everything out and make sure the motor are is clean. The build up of dirt on the coils will not let the heat escape during the cooling process.
Mar 04, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
