Question about Nokia N91 Cellular Phone
Removing batterry Cover
Would u please tell me,if i remove my N91 Battery Cover(Back) with out Turning off my cellphone,Cellphone Can`t Access Hard drive.
Is it Normal?
When the back cover is removed the hard drive is automatically stopped. that may be the reason why you are not able to access the hard drive.
This is normal, and is advised to always switch off the mobile before removing the back cover. It is not safe for the hard disk, it may crash and affect the life of HD
Posted on Jun 02, 2008
Keypad 5130c
i expect that some of the digit in that particular cellphone is not working. if you want to clean your key pad then you need to open it. removed the battery cover, the battery, back cover, untill you see the 6 screws that holds the front cover. Removing the screw will automatically remove the front cover and will show you the key pad. if you want to check the digit which is not working then you fix the battery and holding it firmly press the power On button. assuming that you already know what digit is not working then you can proceed by removing the plastic cover of the keypad and by using pencil eraser you can clean it.. from 0 - 9....
Sep 22, 2013 | Nokia 5130 Cellular Phone
Nakalock ang cp ko ayaw maopen
You might need to reformat your cellphone.. But first, try removing the memory card, sim card and the battery. Then replace back the battery after a minute. Don't put back the memory card and simcard yet. Try to turn on again your cellphone and see if that will fix it.
Nov 13, 2011 | Nokia 6300 Cell Phone
My phone switches on and off a lot
Please remove and clean the Battery contacts then check if it is working fine or make sure whether you have used the compatible battery for the cellphone. Also try removing the Memory Card and Sim Card to ensure that problem is not with those circuit. If the issue still persists, then it might be due to Virus affected to the cellphone or Hardware issue of the Cellphone. In that case please take it to any Mobile Service Centre and Flash it to resolve the issue.
Mar 27, 2011 | Cell Phones
How do I set the date and time on my Tracfone LG420G cellphone?
try turning it off, removing the battery, waiting a little while, and putting the battery back in. If that doesn't work you'll have to call customer service, who (if you get someone who knows what they're doing) will probably give you a bunch of numbers to put in to code entry mode.
Mar 05, 2011 | Cell Phones
Deadphone after recharging, message says
try use a good battery. if it does not work, try check on the connecting pins on the battery connector of your cellphone. if still a problem, try disassemble the cellphone to check the battery interface on your cellphone, clean both connector and the interface of your cellphone... if still a problem, best to repair it to a nearest cellphone technician...
Jun 01, 2010 | Motorola Mobility RAZR V3
I removed my battery to change the sim card. The
ya may be do change bateery then try to switch on your mobile phone
May 25, 2010 | Nokia 6730 classic Cell Phone
I have the same problem
your batterry is too weak or weak amperage for your cellphone you need to replace it a new one battery.
Aug 01, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Problem removing battery cover of cect i9 cellphone
Usually these covers slide off. Look at it carefully and you can see that there is only one direction it could possibly move. Push it in that direction with both thumbs. I am not familiar with that particular model.
Jul 24, 2009 | Cell Phones
My Nokia n91 4Gb hang anytime i replace the battery cover
u had better to update it............. or format..
format code *#7370#
thank u.....
May 11, 2009 | Nokia N91 Cellular Phone
N91 is offline
hi me also had faced the same problem 1yr. back... then i went to Nokia care and submitted my phone and they sent it to main office where it got repair. so i suggest to you just consult with ur nearrest nokia care.
Apr 06, 2008 | Nokia N91 Cellular Phone
Nokia N91 Cellular Phone Logo
158 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
