Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
My external Hard drive of Western digital is not geting read in my deck pckindly solve my problem.
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
I cannot put files on my external hard drive
just plug your hard drive in another noze of usb...
if u have loose connection in usb then it will happen. try to copy small size of data
Sep 01, 2012 | Western Digital My Book Essential 1TB...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
Wester digital external is on computer not reading it
Is the drive operating normally except for the lights not working correctly?
Nov 22, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
My computer recognizes the western digital but i cant view my files.
just update the chipset drivers of ur system form the vendors site,,, tat ll solve the issue...
Jun 02, 2009 | Western Digital 250GB MyBook External USB...
External hard drive not being read by media player
did you find an answer to your question? I am currently having the same problem. The USB LED flashes and takes a minute to scan, followed by a pop up on the tv saying unable to recognize hard drive. help?
May 14, 2009 | Western Digital My Book Premium ES...
Western digital 500gb external hard drive ticking noise- Help !!!
There is a number of data recovery solutions online. Just google it. I would recommend one that sends out a static sensitive bag for transportation. But the customer service rep you spoke with, is probably right. The actuator arm has probably locked up and is failing to move back and forth reading and writing to the platters. Good luck and i feel for you with it being your new born on the hard drive.
Mar 10, 2009 | Western Digital External USB 2.0 80 GB...
Cannot Read External Western Digital Mybook 500GB Drive
I have ".Window 7." Sometime I see a icon and it shows the drive size and can't read and my work. Yes, I do save my work on my hard drive, but I also want to save it on my external drive. . I even reboot.
Jan 13, 2009 | Western Digital 500GB My Book World...
External Hard drives
I will recommend you to use Western Digital I my self alos using a western Digital and its very reliable to use , So I will go for buying that one and it will be a big help for you...
Hope that helps.......
Aug 18, 2008 | Computers & Internet
Is there a way to recover lost data from my Western Digital My Book??
Yes, there is a way to recover lost data from a WD drive.
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Best regards!
Jan 06, 2008 | Western Digital My Book Essential Edition...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
75 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
