Question about ASUS P7P55D PRO Motherboard
Realtek Ethernet adapter often fails on boot
Builtin Ethernet adapter often fails on boot and can't detect the cable. Same cable works elsewhere and the network stays up and functions fine when it works. Latest bios didn't help. Is there any known problem or fix?
Unplug or turn off power supply for a minute and then restart.
Posted on Jan 01, 2011
  • bogoboy_ll Jan 01, 2011
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
Ethernet controller for msi k9n6sgm-v
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
May 25, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Benicia GL8e (Asus IPIBL-LA) motherboard in HP pavilion - need a network driver
hope this helps
May 09, 2011 | Computers & Internet
KV8-X motherboard. I have a network card installed, but I keep getting new hardware found for ethernet. I try to disable the ethernet card via system. I can't connect to internet.
hope this helps
Apr 26, 2011 | AMD ASUS K8V-X (MBASUSK8VX) Motherboard
WILL NOT LOAD OPERATING SYSTEM. ERROR AS FOLLOWS. For Realtek RTL8101E/8102E PC-E Ethernet Controller v1.08 (080408) PXE-61: MEDIA test failure, check cable PXE-MOF: Exiting PXE ROM. Operating System...
It sounds like it's trying to boot from a network. Did you change the boot start up in the BIOS? If not then it's trying to boot from the Ethernet port because your hard drive is not being detected or your software is corrupted.
Feb 10, 2011 | Dell Inspiron Mini 10 Notebook
Toshiba Satellite A215-S4747 does not start up.
Have you tried booting from a cd?
It sounds like you hard drive has failed.
Dec 31, 2009 | Computers & Internet
I keep getting intel undi pxe-2.1(build 0892) copyright (c) 1997-2000 intel corporation for realtek rtl8100/8101e fast ethernet network adapter v1.02 (060510) pxe-e61 media test failure check cable...
Your laptop is trying to boot via LAN(network). Possible the HDD is not being detected by your system that is why it could not boot to windows. Try to boot up without the ethernet (your internet cable) connected to it and see if it works. If not, you may have a bad HDD.
Hope this helps.
Dec 19, 2009 | Toshiba Satellite A135-S2276 Notebook
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
PC will not boot.
Hi , without explaining all that is happening ,your pc harddrive has failed.The pc is looking for an operating system but cannot find it.
Dec 08, 2008 | Toshiba Satellite A135 Notebook
Dell Ethernet Network Adapter not being recognised
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
ASUS P7P55D PRO Motherboard Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
