Question about Zanussi FLA1001W Front Load Washer
Making grinding noises during spin cycle - Zanussi FLA1001W Front Load Washer
More than likely the bearing is gone
Posted on Aug 10, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
Jan 08, 2013 | Whirlpool WTW4800XQ Washer
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Grinding sound during spin cycle
Is this a front loading machine? Also whats the model number when you open the door? If this is a front loading machine and you haven't been using HE soap, it's almost certain it's the brearing.
May 25, 2009 | Washing Machines
Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | Washing Machines
Zanussi FLA1001W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
