Question about Homedics PC-400 Pro Clipper
I has a PC-500 clipper set. I am in need of a power cord. It does not appear to be a generic type. How do I go by getting one? thank you David
I have the same situation. I've contacted Homedics and was just told its no longer made. Bummer. I guess we are both out of luck!
Posted on Jul 19, 2012
Where can I purchase the Wahl Wahl Hair Clipper Taper Replacement Round Power Cord 00647-500
Wahl Clipper
3001 Locust St
Sterling IL 61081
815-625-6525
OR--Electric Shaver Service 888-476-1785
Aug 25, 2014 | Wahl Hair Clipper Taper Replacement Round...
Power goes in and out
Depending on how much use it's gotten or the way it's been stored when not in use it could be a cord issue, either a wire that's not connected completely anymore or a faulty wire. Is the power going to the clipper effected at all if you bend of wiggle the cord when this happens?
Apr 02, 2014 | Andis Clippers Prof Special Ed AGC2 Super...
Conair hair clippers repair
It could be the switch is shorting out or the cord is. If it doesn't cut off when you move the cord it is prob the switch.
Apr 22, 2013 | Health & Beauty
Adapter for panasonic hair clipper ER147
panasonic ER147 hair clipper adapter is AP-22290 charger power cord replacement recharge adapter 220 volt for panasonic er147 national or panasonic hair clipper.
http://www.menelectricrazor.com/panasonic-er147-charger-power-cord/
Jan 13, 2013 | Health & Beauty
The power cuts off when the cord is in a certain position. The problem would appear to be near the base where the ac conects to the clipper. Is this something I can fix myself?
You can take the lid off the clipper (make sure it is not plugged in) and check that the power cord terminals did not come loose. However if that is not the problem, you probably have a bad cord that needs to be replaced. If you return it to Wahl factory in Sterling, IL, 2900 N. Locust St., they will probably replace it for free.
Sep 23, 2009 | Wahl 79110 Hair Trimmer
I need a power supply cord for Ultra LCD30-500
if you have the power supply and all you need is the cord, it looks like the cord is the same as a cord for a computer power supply.
if that not right , reply will look somemore have a good day please remember to rate bama46, thanks
Aug 23, 2009 | Ultra LCD30-500 Television
Recharge Stand for Hair Clipper
This link looks promising, but you may have to consider purchasing a new one, hopefully not! I would assume that this one has such a lower price than the rest and lists contents as "charger" so I assume it contains the charger only. Hope this helps
buy power cord for Panasonic cordless Hair clipper ER152 Google Search
If you need further help, I’m available over the phone at https://www.6ya.com/expert/hannah_786669930d76a4e4
May 22, 2017 | Health & Beauty
Monitor is busted
Hello David,
I think along the lines like you. $500 dollars is a good chuck of money and alternatives would be my first choice. My suggestion is to check both ends of the cable harness the plugs into the screen and to the mother board. Make sure both ends are inserted properly.
Next thing is to test - power up the laptop and see if that made a difference. If not, it may be the screen or the motherboard. So test further by pluging in an external monitor to check to see you get a good picture/image. If so, then that means you need to replace the laptop screen. If you dont get a good picture/image, than that means your motherboard needs replacing.
Hope that helps and good luck.
Jul 20, 2008 | Dell Inspiron 700M Notebook
945GZT M V1.0
David i take it you mean you played with the bios screen ?
if so you can remove the power cord then open the side of the computer and remove the bios battery (big silver watch type battery on the mother board) leave it for around 15 mins replace the battery then the power cord you will find an error screen when you switch on.
its normally f1 to load default settings and continue the boot
that should solve it
Mar 22, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Homedics PC-400 Pro Clipper Logo
208 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
