I have an ACER Aspire 3050 laptop. The keyboard is not responding to impact (must hit key multiple times). Battery does not hold charge; are the two related? Respond to billyball44@gmail.com Thanks.
  • 4,737 Answers
I don't think these two issues are interrelated with each other. Regarding your Keyboard, before we proceed, you need to try with another external usb/ps2 keyboard. Connect an external keyboard to your laptop and check whether it works or not. If it isn't, then the problem is with your motherboard, you need to go to a Service center or call a technician. If in case the external keyboard is working, then, first of all clean the keyboard, update its drivers. I would recommend you to open it apart and check the interfaces with the motherboard.
Now with your battery charging problem, let's assume it's not the culprit, prior to any measures/steps taken, please clean the plug and the jack of the laptop's charging interface and Dc adaptor's plug respectively. Don't forget to clean the interfaces on the battery and on the laptop battery compartment. You can use a soft brush dipped in alcohol/spirit/acetone. After they are dried, reinstall the battery and reconnect the plug. Now power on the mains for the adaptor. If it's working, then the problem is only with the contact points, perhaps rust or prolonged used might caused this.
On the other hand, if the problem persists, you need to boot the laptop without the battery being installed, means only with the power adaptor so that you can find out which one is the root of the issue. Remove battery and power on the System with the dc adaptor connected to the laptop.
You last option is to replace the battery or try with another working battery. Same problem, the your power supply unit is malfunction, you need to call a technician to get it repaired for you. I would suggest you to inspect with every possibilities and call up after you are sure that the problem is with the Power Supply Unit.
Good luck.
Thanks for using FixYa.
Posted on Jul 06, 2010
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
How do i unlock the keys on my acer keyboard
Do a hard reset: turn off computer, remove ac adapter and battery, hold down power button for 20 seconds, put battery and ac adapter back on, then turn on computer.
Feb 25, 2010 | Acer Aspire 3050 Notebook
My Key board dosnt work on my acer aspire 3050 but
Log into safe mode and then try a system restore
Click on start and then all programs
Click on accessories and then system tools
Choose system restore on the list and restore to an earlier time
Then choose a date at least a day before this first happened
Please let me know the results
Dec 29, 2009 | Acer Aspire 3600, 5030, 5500 Keyboard...
Acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
Dec 06, 2008 | Computers & Internet
Acer 3050 notebook.
sometimes corruption in windows can occur this kind of problems...but for now you can use a USB DRIVER LESS keyboard...to log in
Sep 06, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire 3050 keyboard issues
go to my computer, right click, properties, device manager, look down list for keyboard, click '+' sign, you will see your keyboard listed, right click select uninstal, then restart notebook it will reinstall itself and should be working as normal.
Sep 03, 2008 | Acer Aspire 3050-1733 Notebook
Keyboard Malfunction
I suggest you to remove battery.
If this is still not working, your keyboard or motherboard is bad.
Did you spills any liquid on your keyboard ? if you did, probably only your keyboard.
From your explanation, i suspect it's motherboard.
Jul 21, 2008 | Acer Aspire 3050-1733 Notebook
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
Keyboard locked during bootup
My Acer aspire 3003 keyboard and touchpad both started to lock up recently. I use it with the battery removed, it avoids the problem. The battery wasn't holding much charge anyway.
Jan 20, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Apr 06, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
David Payne
David Payne
