Question about Carrier 52PQ-515---3 Premier Series Heat Pump, 15000BTUH, 5.0KW, 230V PTAC Air Conditioner
Furnace runs, fan turns on but it's not blowing through the registers
  • 6,993 Answers
Find the circuit breaker for the furnace and turn it off for 1minute or more and turn back on. This will reset your furnace.
But if that does not solve the problem, check the air filter inside the furnace to make sure it is not clogged. Even if it does not appear too dirty, pull it out and clean it according to the directions because sometimes even a minor dirty filter can be enough to block airflow.
Good luck.
Posted on Jul 06, 2010
  • kcue1114 Jul 06, 2010
    could it be anything else besides this? is this a common solution?
  • Walesarumi
    Walesarumi Jul 06, 2010
    yes, this is a common solution, likewise a common problem with furnace. But the solution might not work if there is more to the problem.
    Try the solution first and if it doesn't work, let me know as there will always be a plan B.
    Bye for now.
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
I have a evcon EB12B where is the reset button. The blower stays on even if heater is turned off at thermostat. I have to turn off in breaker box
This may need the furnace technician to repair.
I can locate the manual for your heater and the parts list but I cannot locate any reset button.
Blowers that run all the time have either a stuck fan relay or depending on age, have either a defective "fan control and limit switch" or a breaker that operates the fan. When the furnace ignites the fan waits until the air get hot before it blows. When the heat goes off, the fan continues to run until the furnace is cool.
You probably can replace the parts yourself but please make sure it runs safely. The making sure is what the furnace tech will do.
Apr 18, 2015 | Heating & Cooling
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Furnace will not run when hooked up to electricity
Go to your thermostat and access the fan mode. Change the fan mode to Automatic, AU. This will stop the AC fan from blowing when the furnace is turned on. If the fan mode is on Hi or Lo and the furnace is turned on it will turn on the AC blower. Bad design...
Mar 02, 2014 | RVs
Amana furnace not blowing hot air
My heating system is running so well because I have Amana furnace.
Nov 09, 2012 | Heating & Cooling
Our furnace seems to run on idle constantly . we are using more oil but not electric if i tap on the box it stops but starts again a few minutes later??
We need to get a few details cleared up:
Is it the Furnace (Oil burner) that is running, (on idle you called it..)
or is it the FAN that is running?
What are you tapping, that shuts off what?
Is the fan that blows the air around the home shutting off, or the burner?
(When the burner is running, there is a loud roar!-- the fan should be much quieter..)
If it is the fan that is running,-- I might ask, is the air coming from the registers too cold?-- for with the fan running, you are getting all the heat from the oil that was burned. But naturally, you don't want it to be uncomfortable.. So-- you can open the cover on that Fan control switch, and raise the temperature at which the fan turns ON and OFF..
Let us know what you find.
Mack B
Dec 28, 2010 | Heating & Cooling
Furnace turnoff just before the blower go on.
You are to be commended for noticing this sequencing of events-- Good observation!
You need to adjust the Plenum control switch. (Or fan control switch)
Usually at the top front of the furnace, is a Fan control switch--
It is called the Plenum switch-- and it senses the temperature of the Air being heated by the fuel--
(Is your furnace Oil or gas?-- if Gas-- is it LP or Natural?)
This switch Has a cover that can be removed-- inside is a round dial, with some adjusting screw, and Degrees stamped on the perimeter of this round dial.
You can take the cover off, while the furnace is running-- (Just do not touch the screw terminals that have electric power to them--
You can rotate this dial, and it will turn the fan on-- (Or if the trip levers are mis-adjusted-- it might shut off the burner-- just rotate back the other way, and it will re-light etc.--
The purpose of this control is to make sure your fan is not blowing COLD air.
So-- lower the 'ON' switch tripper, down lower, so the fan will turn on sooner.
You may have to loosen a set-screw-- but usually they are just friction held-- and can be forced to slide (rotating CCW) to the lower temperature setting.
(If you get it too low, it will be blowing cooler air than you like at the registers.)
However-- to get the most heat from your furnace energy source-- you want the fan to come on as early as you can tolerate-- That will be delivering HEAT to your occupied space sooner, and giving yo more of those dollars you are spending on fuel, in the orm of heat in your house!
Tell us more
Mack B
When range burners set to low they go out when house furnace fan turns on?
This is a common problem when the furnace register is located in or near the kitchen. You will need to close the register(located in the ceiling) or adjust it so the air is not blowing toward the range burners. They also make deflectors that you can install on the register to direct the air away from the range.
Dec 18, 2009 | Kenmore Kitchen Ranges
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
