Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
My Pentair legend isn't picking up debris like it
My Pentair legend isn"t picking up debris like it used to. Only one of the water pumps inside the machine is working
  • 990 Answers
You will need to take the unit apart and useing a wire clear the jets in the throught then flush with good pressure water. Check your filter to see if it is passing derbs. Also check your finger screen at the wall in the hose connection.
Posted on Jul 07, 2010
Water management system in pentair legend
Check the finger screen in the wall adapter, which is located at the wall, that the hoses are connected to. Inside that is a screen, and it's probably plugged with debris.
May 06, 2014 | Pentair White/Gray Legend Platinum...
Wheels turning slow on legend pool cleaner
Water supply issue...
Most likely reason = clogged finger screen at pool wall fitting adaptor, this needs to be cleaned regularly. If no finger screen, then the debris that would've been trapped, has clogged your internals of the cleaner!
all orifices will need to be cleaned.
Oct 28, 2013 | Pentair White/Gray Legend Platinum...
Legend pool cleaner rides on its side
check ballast ball if water inside replace ball
Aug 18, 2013 | Pentair White/Gray Legend Platinum...
My pentair legand II cleaner rolls everywhere but doesn't **** anything up
Almost always with these pool cleaners, this means that either the debris bag is full or that you have a hole in the bag that is preventing proper suction of debris. Check the bag and clean or replace if necessary.
Nov 08, 2010 | Pentair White/Gray Legend Platinum...
Just bought a used legend and it seems to be In good shape. It needed a new bag. Bought one today and began using it. It picks up fine but after a little while it ends up o it's side and stays there. Any...
their should be a ballist weight inside the unit in the bottom. Be sure that is in place. Then check all the floats and be sure they don't have any water in them. Also make sure your hose leingth are correct.
Sep 07, 2010 | Pentair White/Gray Legend Platinum...
My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
May 25, 2010 | Pentair White/Gray Legend Platinum...
Our three year old Legend keeps tipping over while
Sounds like the head float just below the debris bag is bad. Check to see if it has water in it. If so then replace it. That float helps keep it upright.
May 23, 2010 | Pentair White/Gray Legend Platinum...
Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Oct 04, 2009 | Pentair White/Gray Legend Platinum...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
357 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
