Question about Hayward SAND FILTER, PRO SERIES
What to do about 14 psi ?
I have a 1995 Vari-flo model 71113. The pressure is only at 14psi. I was told when we bought the house that 25 is the correct operating pressure. What can/should I do? FYI- pressure gauge is brand new. Pool is inground. Thank you.
  • 760 Answers
The actual pressure depends on how clean the sand is, how well the pump is pumping, how clean the skimmer and pump baskets are. The rule of thumb would be when the filter pressure raises 8-10 psi above whatever the pressure was when you first started the filter with clean sand, clean baskets, good pump, When it reaches the 8-10 psi, it's time to backfulsh. A low pressue, with adequate return flow is what you really want. See Hayward's web site for a manual. http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 07, 2010
Gould j5s, pump not going above 15 - 20 psi, does this sound like it could be a priming issue or not since it is pumping some water?
how much pressure do you want with a 15 to 20 psi, really what are you pumping house water, you need more pressure to supply a home like a 60 psi with an exterol tank
Nov 18, 2013 | Jet Flo 04325143A Marine Heavy Duty Water...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Air bubbles in sight glass but pressure is good
leak on intake line or bad seals in pump
May 08, 2012 | Hayward Pool & Spa
How much compression is there per engine cylinder?
14psi x 8 = 112 where compression ratio is 8:1
14psi x 9 = 126 where compression ratio is 9:1
14 psi is konstant for atmospheric pressure
air temperature will change actual results
Jan 25, 2011 | 2001 Chevrolet Blazer
I CAN NOT GET PRESSURE TO MY SAND FILTER i KEEP TRYING TO PRIME IT BUT IT HAS NOT WORKED i HAVE A hAYWARD S 240 AND A Vari flo I'm just opening my pool on Aug 7, 10 it always happen when we open the...
There is a air leak somewhere between the pool and the inlet to your pump --- probably the connection going into the pump housing from the pool. Put plumbers putty around the joint. Keep checking until you find the leak and the pump actually draws a suction. The impeller is sound, right? If not, replace it and the seal between the motor and the pump housing.
Aug 08, 2010 | Hayward SAND FILTER, PRO SERIES
I have an appolo spa explorer model...bought it
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Oct 29, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Hayward vari flo valve
If the spider gasket in the vari-flo valve is no good, you will usually notice one of two problems.
1. Water leaking out backwash port while filter is operating.
2. Valve positions are really difficult to change.
The way to check this is if you are able to move one or two of the "spokes" in the gasket freely(out of the track it sits in) once the top of the valve is removed.
If so you need to replace. The gasket is usually held in with a silicone sealant. Once you remove the old gasket. You will need to scrape any remaining rubber from the track it sits in. I've found that a brass brush from a pluming supply store or home depot along with a flat head screwdriver is usually enough to do the removal.
I always used Permatex Blue RTV sealant on all valve jobs. It can be found at any auto parts store or sometimes Walmart. Follow the instructions for curing. Once cured the gasket is good as new.
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
307 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
