Question about Canon i350 InkJet Printer
When printing the result is patchy do the heads need cleaning and if so how do I do this
    Scholar:
  • 117 Answers
Go into your printers properties and do a nozzle check. To do this follow the following steps.
***Click "START"
***Go to "Printers and Faxes"
***Within this new window "right click" your printer and select "properties"
***You will now see a bunch of tabs at the top click on the one that says "maintenance"
*** then click on "Nozzle check" this will pop up a box that will give you 3 options.
***click on "Print check pattern" this will do a print out and if the grids show missing lines then you will need to do a printhead cleaning.
*** click the option that that says cleaning. Your printer will then clean the printheads and once its done it should ask you if you want to do another pattern test. Run it and see if things change.
If they dont then you will need to do another printhead cleaning. If the nozzle check printout doesnt get any better you might need to replace the cartridge or cartridges.
Best of luck..
Please take the time to rate my solution to your printers problem.
Posted on Jul 06, 2010
When i am printing it is all too red and very very grainy and patchy which cartridge needs changin
You should be able to print a test page which will show which carts need changing. A print head clean could also solve the problem.
Without knowing what make/model of printer and OS cannot advise any more.
Jan 08, 2011 | Computers & Internet
My black ink is patchy, even after deep cleaning
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 16, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Incomplete patchy printing
Please try to do a printer head cleaning. You can do it by getting a small earbud and soak it with a small amount of water. Or try to adjust it by doing an alignment. Usually, the printers have this functionality. Please refer to the user manual.
Aug 13, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Grid pattern on Canon MP760 test print is patchy and cleaning process does not fix it.
You can try to remove the print head and ink cartridges.
Soak the head in an ammonia10-20% solution with warm water for 30-45 min.
Dry the head completely and re-install.Now run your grid patter,
It sonds like(from the grid reference)that only the black is clogging.This is a pigmented ink and tend to dry if not used for months at a time.
Jun 20, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Patchy printing
Problem is with either with cards or with print head's mechanical alignment. Try with some different cards and for head get it tested by some authorised service person.
Nov 28, 2008 | Evolis Pebble 3 ID Card Printer Package...
Clean jets
Go to the Solutions center and click on maintanance. That should give you a page that has a "Clean Nozzles"button,. Click on that and the machine should run the trest. Run again if the test page still comes out with patchie printing.
Jul 08, 2008 | Lexmark X1270 All-In-One InkJet Printer
Canon pixma ip1000
as you are telling the problem is inside your printer.please get it serviced.
Apr 05, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i350 InkJet Printer Logo
265 people viewed this question
old marine
old marine
