Question about Aqua Cannon Adjustable Power Sprayer
Looking for an Aqua Cannon Fluid Dispenser, where can i find one? the one i have is broken.
  • kf4siq Jul 07, 2010
    thank you for the information, i appreciate it. i will go to ebay now and order the replacement.
    President:
  • 1,561 Answers
You can get a replacement for your Aqua Cannon Fluid Dispenser at ebay site, the site have almost all equipment and device for sale.
Type ebay.com on your web browser and order for your Aqua Cannon Fluid Dispenser, it will be delivered within the very shortest time.
Take care.
Posted on Jul 07, 2010
Where in naples fl sells aqua cannons?
they both have websites . why don't you check there . we have no idea
Dec 18, 2015 | Aqua Cannon Adjustable Power Sprayer
Troubleshooting
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Gd bless you
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
When I attatch it to any hose the water spays out around the connection to the hose.
It should have a rubber washer,just like a garden hose.I would take the wand to a local hard ware store and just get a new washer that fits it.
May 13, 2011 | Aqua Cannon Adjustable Power Sprayer
Broken rollers on shower door
The rollers for most shower doors are a stamdard size and are available at most hardware stores. The Bigbox stores might even carry rollers for you specific make and model.
Feb 25, 2010 | Aqua Brass Prestige Shower Kit #2 AQUA...
Looking for a replacement hose end washer for the aqua cannon.
Local hardware store had an acceptable replacement part. Thanks
Oct 12, 2009 | Aqua Cannon Adjustable Power Sprayer
Plugged in and turned on but doesn't move
look at the rubber belt wrapping the wheels, there are some little rubber numbs along the belt in order to grap the wheels and make them move. If some of the numbs are broken, the grab is too week to move the wheels. I guess, replace the belt is the only solution
Aug 11, 2009 | Aqua Vac Tiger Shark
Lost instruction for Thetford Aqua Kem and Aqua rinse.
Aqua Kem recommended dose: 75ml of fluid per 10 litres of waste tank capacity.
Aqua Rinse can be used daily as a toilet bowl cleaner. It will lubricate the bowl to prevent staining and once in the tank will help lubricate moving parts down there.
Jun 24, 2009 | Sport & Outdoor - Others
It gets freezed in the aqua pura mission!!
well look on the bottom of fall out 3 and if it has alot of scatches theres ur problem
Jun 19, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
Where can I purchase a replacement soap bottle?
Contact:
Roberta's, Inc.
24 W. Franklin Street
Shelbyville, IN
46176
(800) 428-9726
(317) 398-4453
http://www.robertasinc.com
May 24, 2009 | Aqua Cannon Adjustable Power Sprayer
Aqua Cannon Adjustable Power Sprayer Logo
99 people viewed this question
Top Aqua Garden Experts
Dennis Key
Dennis Key
john h
Are you an Aqua Garden Expert? Answer questions, earn points and help others
