Question about Logitech Rumblepad 2 Game Pad
Stering problem - Logitech Rumblepad 2 Game Pad
Mercury Sable 99 power stering problem
ALL FORDS WILL DO THAT THERE IS NO BY PASS IN GEAR BOX OR RACK , WITH ENGINE OFF THEY WILL OVER FLOW. ONLY FORD SORRY TO SAY YOU FIX IT BUT IS ALL THE SAME ..
Feb 16, 2013 | Mercury Sable Cars & Trucks
Power srering fluid turned clay color
Yes, this is a problem. The clear power steering fluid is a mineral oil base and the red Lucas additive is petroleum base. Your car uses the red petroleum base, which is actually Dexron ATF (automatic transmission fluid). Lucas is great stuff, the person at the parts store just doesn't know their stuff. You need to flush the system to save your pump from going out very prematurely.
Jan 28, 2013 | Cars & Trucks
My car power stering light comes on and then the wheel is hard to
this system can be tested for codes, I would suggest you have the dealer do this test, all the parts are very expensive so guessing is not a good idea. most probale cause is a wheel motion sensor on the steering column.
Jun 17, 2009 | 2005 Chevrolet Malibu
STERING BOX PROBLEM
hello,road grip is not good,better to perform wheel alignment,they also check the condition of your steering component and suspension bushing,ty
Apr 22, 2009 | 1998 Mercedes-Benz S-Class
Leaking power stering
only a right turn? Its probably a seal in the rack..
Mar 11, 2009 | 1991 Chevrolet Corsica
I can not see where is power stering .l want put power stering oil
should be on the left side of motor look for a small dip stick read the stick the tranny stick looks close to it
Mar 03, 2009 | 1996 Honda Accord
Stering can't go down
The gears on the motor are bad and the motor has to be replace.
Nov 14, 2008 | 1996 Lexus LS 400
Power stering pump
Is this the 3.4L DOHC engine or the 3100/3400 engine?
Oct 17, 2008 | 1997 Chevrolet Monte Carlo
Used power stering pump asembley for 1987 cheverlet s10 pickup 2.5 four cylender
call our local scrap yard they gonna have what you whant thanks for using fitya pierre235
Feb 08, 2008 | Car Audio & Video
Car is in Park and everything is locked up
what kind of car. if our car is park on a hill or something like that stering turn. turn the stering wheel and try to turn ignition the pressusr of on the stering gonna prevent from turning ignition dont forget to rate this cheers
Jan 20, 2008 | Computers & Internet
Logitech Rumblepad 2 Game Pad Logo
74 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Lyle Siemens
Lyle Siemens
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
