Question about Zebra Z4M Printer
The cutter on my Zebra 4M plus is jammed. I have cleared the path completely, but now when I turn on the printer, the cutter will cut 3 or 4 times rapidly, then display the 'Cutter Jammed' error message. How can I clear that out?
2 Suggested Answers
SOURCE: my zebra 4M+ get me a cutter jammed status
Sometimes debris builds up in the bottom of the cutter assembly preventing the cutter from going all the down. There is a switch inside the cutter which trips the "jammed" error if the cutter can't go all the way down. The cutter can be removed and disassembled to remove the problem. Caution should be exercised. There are washers and springs on the cutter face plate guide screws which have to be removed.
Posted on May 20, 2009
Feed option not working but printer ready.
Dear jafar,
just first you conform there is no paper jams in your printer then only i will tell it is motor issue///
Jun 18, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Zebra 110xi4 labels jam going into the cutter
This is usually related to the setup of the printer. Check that there is no backfeed set up, and that the settings are on for calibration on head close.
Oct 10, 2012 | Zebra 110Xi4 203DPI 10100 CUTTER W TRAY...
Zebra 4M Plus printer keeps printing same label
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Zebra Z4M Printer
Zebra 4m printer. Turn on and pause and error
You have a bad logic bd and it needs to be replaced our repaired.
Rory
Dec 20, 2009 | Zebra Z4Mplus Label Printer
Has paper jam message all the time, clear it and it works for one or 2 pages and then jams again appears to have problem picking up the paper
What happens to these older printers is all of the rubber rollers for the paper handling dry up and basically do not function correctly.
You can purchase a rubber roller rebuild kit that comes with complete instructions from HP.
It's really very easy to do.
Good Luck!
Oct 11, 2009 | HP LaserJet 4m plus Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
My zebra 4M+ get me a cutter jammed status
Mar 26, 2009 | Zebra Z4M Printer
Cutter Problem
the cutter has that bushing attached to act as a tire as it travels across the scan axis, these infrequently wear out and cause the carriage to basically drag the blade behind causing your uneven cut pattern, the cutter must be replaced. If you need direction on how to do so please contact me
Apr 16, 2008 | HP DesignJet 1050c InkJet Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Zebra 4m
If you are in rewind mode and don't rewind the printer will pause while the rewind spool tries to catch up.
Jan 10, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4M Printer Logo
158 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
