I,ve done a cad drawing of a curved object and want to print it full size (i.e.scale of 1:1)so we can use it as a template.My printer is a canon IP4200 and does A4 pages. The full size item is 950mm X 500mm.I realize I will have to lay out the pages as a puzzle.Can this be done?? Look forward to a reply, Alan
  • 2,039 Answers
You should be able to do this using the "Poster Printing" option in the printer preferences. On the Page Setup tab, select Poster Printing as Printing Type, then click on the Specify... button. Select Divided into 16 (4 x 4) for the Image Divisions. This should give you enough area for the size you specified.
Posted on Apr 18, 2008
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Printing on a dvd
You might try this link:
Adobe - Canon Templates
Or - try editing a pre-made template. Perhaps delete that template's artwork in Adobe Photoshop.
Dec 21, 2013 | Office Equipment & Supplies
I want to draw a block on sheet like graphical in different sizes to prepair a chart. Is it possible and how. thanks bimal
You could purchase this software at a price but maybe overboard for what you need this is what it does basically
Smart Draw (CAD environments often involve more than just shapes. As in the manual drafting of technical and engineering drawings, the output of CAD must convey information, such as materials, processes, )
CAD may be used to design curves and figures in two dimensional(2D) space; or curves, surfaces, and solids in three-dimensional(3D) objects.
for more info take a look at the following url
http://www.smartdraw.com/specials/ppc/cad-design.htm?id=31748&gclid=CJaGh5Hxr6cCFce7KgodSF-REQ
Mar 02, 2011 | Computers & Internet
My printer won't print on a full scale.. meaning
this has to be set from the wizard for the printing job ...look for the edges size..but when you print on paper ..something like a full size A4 image ...it will always leave a 5 mm edge as default setting ..But like I said..initiate printing ..and in that wizard set the edge to 0 or ..click to remove edge if it is possible..anyway if it is possible there is the only location where you can change it ...and I'm not sure if it can be done permanently
Apr 29, 2010 | Office Equipment & Supplies
Mismatch paper size error
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print
on the bottom of that screen there should be a scale to paper size drop down box. Scroll to the bottom and your saved name and dimensions should be there.
You will have to setup each individual sized template ones and then just scale to fit each time. Hope this helps
Mar 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
Printed subject comes out too small to read I would like it to be a normal size or number 10 or 12 What do I have to do?
increase your font size change the layout or template you are printing from or scale the print job 150%
May 28, 2008 | HP Office Equipment & Supplies
Page size for CD printing
I think that the CD/DVD printing ability depends on the software that epson bundles with the printer.
I had the EPSON R200 and i could only print CD's from the EPSON PrintCD software.
May 04, 2008 | Epson Stylus Photo R260 InkJet Printer
Print problems
Print to fit page prints thumbnail size image.
trnsp.gif Answer Zoom out to make your design appear on a single screen, drag and draw a box around it, using the Select Objects Tool. Once it's all selected, go to Edit > copy, File > new, Edit > paste. Print from this new file.
Note: this may be caused by an extraneous object on an outer edge of your plan. When you zoom out, pan around your design to see if there is a stray object, which you can delete.
Mar 12, 2008 | Punch ! Professional Home Design Suite for...
Small print
Turn off and unplug the printer from its electrical source for several minutes. Turn off the computer. Turn on the printer boot up the computer. Try to print something. Try checking for viruses or spyirus http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=257&modelid=11993 this is the site for your printer. Scaled printing To enlarge or reduce a printed document by specifying a percentage, select 'Scaled Printing'. You cannot use this setting with borderless printing. 1. Access the printing preferences by opening the printer Properties/ Preferences. For Windows Vista * Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'. * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows XP Home Edition * Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows XP Professional Edition * Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows 2000/Me/98 * Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. 2. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'. 3. In 'Page Size', select the paper size specified in the application. If you select a size that cannot be selected in your printer, a message will display informing you that the setting has been changed to 'Fit-to-page' printing. Select 'Scaled Printing' again. 4. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape). 5. In 'Printer Paper Size', select the paper size loaded in the printer. In 'Scaling', the magnification at which the document will print so as to fit exactly on the output paper size will appear as a reference value. 6. In 'Scaling', specify the percentage. You can select from 20% to 400%. 7. Click 'OK'. Let me know what happens. Good Luck, Tim
Mar 15, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
88 people viewed this question
jasbo
jasbo
