Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Model 2000 disposal will not turn and only hums when turned on
  • A Miller Jul 06, 2010
    Is it jammed? Did you press the reset?
  • Ace Hardware Master
  • 43,501 Answers
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Posted on Sep 29, 2010
3 Suggested Answers
  • 124 Answers
SOURCE: My garbage disposal is not working. Making humming
Sounds like the motor is shot. Generally if the motor will turn then there is not much you can do. Check the warranty on the unit. Warranty varies from one year to 10 years. If it is over ten years old * would just replace it.
Posted on Sep 13, 2009
SOURCE: Disposal made loud grinding sound,
There is something binding up the garbage disposal. Make sure the power switch is off and trip the breaker for that circuit too! Use a broom handle, plunger handle or something similar and use it to try and turn the inside of the disposal. By prying between the sink opening and any raised surface on the bottom of the inside of the disposal with the broom handle you may be able to break it free. This sometimes takes considerable force so be careful not to smack yourself if the broom handle slips. It may take several attempts. Once you can get the disposal to turn, check inside for any debris that may have been forced back into the disposal and remove it before restoring power and testing the disposal is functioning properly. Repeat the process if it begins working normally and suddenly binds up again. There may be additonal debris in the unit.
Posted on Aug 20, 2011
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
IN SINK ERATOR model 55 hums have reset turned wrench still not disposing
Copy following link:
Humming means voltage is less than 80% nameplate, or start capacitor has burned out.
Replace disposal.
Mar 23, 2013 | Electrical Supplies
Insinkerator model 55 hums
Copy following link for troubleshoot walk-thru:
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
Mar 23, 2013 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Dishrag caught un disposal, pulled it out, blades turn, it just hums, it hums even when switch is turned on off!!
If cutter disk turns freely and motor hums, then motor winding has gone bad.
The humming sound means motor is overheating and will stop humming.
I wrote ez garbage disposal replacement steps from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Stuck flywheel, disposal will not run, humminf noise Model: GFC525F GE
something is stuck in it, the humming is letting you know that its stuck. assuming you dont have a disposal turning wrench try this. unplug the unit under the sink. using an old wooden broom handle,, place it inside the disposal , and try and turn the unit. once you free it up, use a flashlight to look inside and remove whatever is jamming it up. once this is done, plug it back in and try it again. if the humming has stopped and it doesn't turn on. at the bottom of the unit is a reset switch. push it in, and try it again ( turn off the power as you rest it)
Apr 21, 2011 | Kitchen Appliances - Others
Disposer is making a humming sound.
If your disposal is humming but not grinding then shut unit off and use a 1/4 allen wrench in the opening on the bottom of disposal in the center and turn it back and forth with the wrench till you get it freed up. There should be a offset wrench that came with the disposal for this purpose but if you don't have it a regular allen wrench will work. Try running hot water thru disposal while you are turning with allen wrench to help loosen up grease. After you get it turning freely remove allen wrench and turn disposal on . Hopefully this will take care of it but if not repeat until it frees up.
If your unit stops look on the bottom of the disposal for a small red button. This is a reset button. Push it and see if it will run. Hope this helps you. Thanks and have a good year.
Jan 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal is not working. Making humming sound when turned on. I tried to press the red reset button but to no avail. Also tried to turn the little dosposal wrench in bottom hole of disposal but...
It is most likely plugged up there is a clap with a butterfly bolt that you turn counter clockwise remove the clamp and have a trash can under it and wiggle it to remove the lower half of the disposal, when it comes off dump it out and clean with fresh water. Then with hands free of the pump turn the disposal back on, it if still hums the motor is bad and you will have to replace..
Sep 13, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
967 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
