My computer has a ASUS P4S333VM mothercoard. The date and time functions have failed. I presume that the battery needs to be replaced. what type of battery is used, where is it located? Please help me.
    Genius:
  • 1,226 Answers
That is located in motherboard a circle (silver) set near the pci slot. like crystal , that is very cheap! less than $.
may this help, melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Apr 18, 2008
I NEED TO RESET TIME AND DATE
presuming you have a windows PC, changing date & time(& even region) may be achieved by double clicking the time at the (typically) bottom right of your screen..here's more details:
http://pch.custhelp.com/app/answers/detail/a_id/580/~/how-do-i-set-my-time%2C-date-and-time-zone%3F
Sep 04, 2017 | Time Computers & Internet
ASUS ALL IN ONE computer ET2221i-b85 The time is not correct and keeps losing time. I want to replace the cmos battery .
Keeping time has always been a problem for computers, as their internal clocks needed something to synchronize with. If you have an Internet connection and use Windows, you can get the time adjusted regularly using a time set function from Windows online. The CMOS battery will have little to do with time settings, unless it goes bad. Then, not only will your date and time go out of sync, so can many other settings in the CMOS. So, unless you are getting a low battery warning, or both the date and time are out of sync, you probably don't need a new CMOS battery and replacement probably won't fix you time drift issue.
In Windows 10, to get auto time sync, go to "Settings", then select "Date and Time". Under this you will see an option to "Set Time Automatically", as well as to select your time zone.
Aug 19, 2016 | ASUS Computers & Internet
ASUS P5GZ-MX: Cmos Settings Wrong - Tryed New Cmos battery and setting time a date howto fix ?
It may just be that the new battery needs to be charged. I would leave it switched on for 24 hours to check. If this doesn't fix the problem, it could also be a failing BIOS chip or the charging circuit for the CMOS battery has failed. If the BIOS chip is not socketed or the cmos charging circuit has failed, you will need to replace the motherboard or find an electronics engineer to replace the failed components, this will probably be more expensive that a new board.
Jun 13, 2012 | ASUS P5GZ-MX Motherboard
VGA : SiS 315 Integrated Video Adapter [AsusTek] Chipset : SiS 650 + 85C503/5513/961 Mother board : ASUS P4S333-VM iam traying many vga driver but my sys not support any driver so can you help. my...
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jun 10, 2011 | ASUS P4S333VM (AP4SRRVM) Motherboard
After bios update my mother board is asking to set date and time on each start up p5qpl-am
This problem occurs when the BIOS battery is flat and cannot save the Date and Time settings.
Replace the BIOS battery, it most likely a coin size 3 volt lithium battery type CR2030.
Apr 29, 2011 | ASUS Computers & Internet
My cp always crashes and asking for the bios
The computer is asking you to go into the BIOS to fix (probably) the Date and Time because it is wrong or some other setting is wrong or corrupted.
This is usually cause by a flat BIOS battery.
Replace the BIOS battery (this battery may be a coin size lithium battery type CR2030) and then go to the BIOS configuration and set the Date & Time etc.
Oct 28, 2010 | ASUS P5N-E SLI Motherboard
I want to download motherboard driver p4s333vm
here is the site try to download here
http://support.asus.com/download/download_item.aspx?model=P4S333-VM&product=1&type=Drivers&SLanguage=en-us
Feb 06, 2010 | ASUS Computers & Internet
I CAN'T CHANGE TIME AND DATE IN BIOS.SECONDS DONT COUNT
Problems with BIOS time is usually associated with the CMOS battery. If the battery is running low all types of random problems can be caused. I would replace the CMOS battery and see what happens and if the computer does the same thing then we can look from there.
mpawlak908
Oct 17, 2009 | ASUS Computers & Internet
Install os on my asus p4s333vm motherboard
The OS has to be installed on the hard drive, not the motherboard.
If you have the user manual, it is just a matter of following the instructions, and in most cases with the cdroms or dvd, usually no problem.
You gave no information if another OS is on the hd or not.
If you have another OS on the MB, and want to upgrade, that is one way. If you want to wipe the old OS off and reformat the drive and start over, the instructions to do that will come up as an option as you put in the disk and proceed.
Sep 08, 2009 | ASUS P4S333VM (AP4SRRVM) Motherboard
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
