Question about Microwave Ovens
Alarm on my upright freezer will not go off - Microwave Ovens
    President:
  • 1,099 Answers
All you need to do is to locate where the alarm is position, remove it and check on the contact relay , it might be closed and not able to open up loop back , replaced if bad .Also check on the thermal switch of the alarm , because this are the likely faulty of refrigerator alarm not able to turn off if the door is closed or not .
Good luck , hope found it helpful
Posted on Jul 13, 2010
Freezer light bulb replacement
my upright is in front top behind lip
Jan 02, 2015 | Microwave Ovens
My hotpoint upright freezer FZ150 has stopped working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 25, 2011 | Microwave Ovens
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
I need to install condenser fan motor on my newly bought freezer to protect it from our upcoming very hot summer. As I've heard that installing such a fan will prolong the life of the compressor. So, I...
One wire must go to Neutral or the black wire where it comes off the main power lead and connects to the unit wiring, The Live wire should be picked up from the thermostat terminal that powers the freezer compressor. In this way the fan will only run when the compressor is operating. If the fan motor is a large one , more than 200 watts, you will need to run it through a relay to prevent overloading the thermostat contacts.
May 10, 2011 | Microwave Ovens
I have a skandiluxe chest freezer and the orange light is on - is this right?
On my Skandiluxe CF309 chest freezer, the ORANGE LIGHT IS FAST FREEZE and should be depressed to quick freeze when adding newly bought items as the temperature will go up when you've opened the lid for prolonged periods. This is also used to drop the temperature when restoring after defrosting. REMEMBER TO TURN THIS OFF. Also, take note of the gauge in the inside of the freezer which tells you which setting to switch the dial to according to how full the freezer is, and therefore the most energy-efficient setting.
The red light is the warning or "alarm" and will light up when the temperature is too warm.
The green light is a "control" light and I can't remember what this is for, but I don't recall seeing it on in the 15yrs or so that I've had the freezer.
TO DEFROST:
(The drain comes out directly underneath the drain hole and there is no hose. Not a very helpful design. I found that if you tip the freezer forward and scoop out as much water as you can, then mop up the rest with a large bath towel, it should do the job.
BTW if you are planning to defrost the freezer (or any freezer for that matter), once you've switched it off, if you have access to a hand-held steamer, and place something like an empty plastic box to catch the ice (we used an unused litter tray as it's the perfect size to catch all the ice in an upright freezer), it saves a significant amount of time. If you don't have one, it's worth investing in a cheap one with the squeegee function so you can do all the nitty-gritty jobs around the house including the windows in no time and no elbow grease at all !!
Aug 12, 2010 | Microwave Ovens
I have a kenmore upright freezer and it runs continuosly, no freezing issues. It is located in my garage and the temperature is extremely hot. Should my freezer still cycle or could it be my thermostat or...
You may have the cold control set lower than necessary. Make sure the condenser panel is not coated with dust/dirt. If the outer walls of the freezer are the heat-release surfaces, make sure that nothing is on top of, or stacked next to, the outer case that could block heat release. Hope this helps!
Aug 11, 2010 | Microwave Ovens
We have a Haier upright freezer and i can not get the alarm to go off
the reason there is no fan on the outside is because the outer shell of the unit is the condenser. the unit does it have a fan on the inside? also how does that gfasaket on the outside of the door look like? let me lknow
I would leave the door closed unplug it for half an hour. In that half hour go to sears.com customer service, manuals and guides and type in the full model number from the freezer. You should find an owners manual there to print or just browse for an answer. Good Luck.
Jul 06, 2010 | Microwave Ovens
AMANA UPRIGHT FREEZER LEAKS WATER FROM THE DOOR
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 14, 2010 | KitchenAid Architect II KBHS109SSS...
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
