Question about Microwave Ovens
We have a Haier upright freezer model #HUF138PA.. and the alarm will not go off
  • 532 Answers
You can use the manual to control the alarm if this does not work, switch the freezer off, remove the plug for 12hours and put back the plug and switch on the frezer.
If this did not solve the problem and the freezer is on warranty then take it back to Haier for replacement.
Bye.
Posted on Jul 06, 2010
How do I get a latch for Haier Model MWG10051TSS microwave. My door will not open and the latch for the top hook appears to be missing
Check and see if your microwave was made in an overdseas country, or Mexico.
If so, know that parts may not be available.
Otherwise, type "Haier microwave" into your search engine on your computer, and you should eventually see some dealers who might be able to help you with parts.
God bless your efforts.
Feb 17, 2017 | Haier Microwave Ovens
Microwave started beeping while unplugged
If it beeps for just a few seconds after being unplugged from the wall, that's not a problem.
It's likely just the software or hardware feature utilizing a "sanity timer" to alert you when the oven loses line power. It's similar to a freezer alarm or sump pump alarm.
If this doesn't seem to answer your question or address your situation, please e-mail me and remind me of your symptoms and include your full model number as shown on the label.
Dec 28, 2016 | Microwave Ovens
I need to install condenser fan motor on my newly bought freezer to protect it from our upcoming very hot summer. As I've heard that installing such a fan will prolong the life of the compressor. So, I...
One wire must go to Neutral or the black wire where it comes off the main power lead and connects to the unit wiring, The Live wire should be picked up from the thermostat terminal that powers the freezer compressor. In this way the fan will only run when the compressor is operating. If the fan motor is a large one , more than 200 watts, you will need to run it through a relay to prevent overloading the thermostat contacts.
May 10, 2011 | Microwave Ovens
I lost my freezer key.i would like to lock it from time to time,it is a model 20163 upright freezer singel door 16.0 cu ft kenmore.i need the door key please help me if you can.
If this key is the hollow hexagon shaped key.. you can order one through Sears Parts Direct for $6.54 and may be able to pick one up at a local store.. Part Number : 842177
There is nothing special or unique about this particular key.. works for many models across the years. in fact you may be able to get a tool/bitdriver that will work as well.. Security hex bit tools come in a wide variety of sizes.
Best of luck
Apr 17, 2011 | Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
I have a skandiluxe chest freezer and the orange light is on - is this right?
On my Skandiluxe CF309 chest freezer, the ORANGE LIGHT IS FAST FREEZE and should be depressed to quick freeze when adding newly bought items as the temperature will go up when you've opened the lid for prolonged periods. This is also used to drop the temperature when restoring after defrosting. REMEMBER TO TURN THIS OFF. Also, take note of the gauge in the inside of the freezer which tells you which setting to switch the dial to according to how full the freezer is, and therefore the most energy-efficient setting.
The red light is the warning or "alarm" and will light up when the temperature is too warm.
The green light is a "control" light and I can't remember what this is for, but I don't recall seeing it on in the 15yrs or so that I've had the freezer.
TO DEFROST:
(The drain comes out directly underneath the drain hole and there is no hose. Not a very helpful design. I found that if you tip the freezer forward and scoop out as much water as you can, then mop up the rest with a large bath towel, it should do the job.
BTW if you are planning to defrost the freezer (or any freezer for that matter), once you've switched it off, if you have access to a hand-held steamer, and place something like an empty plastic box to catch the ice (we used an unused litter tray as it's the perfect size to catch all the ice in an upright freezer), it saves a significant amount of time. If you don't have one, it's worth investing in a cheap one with the squeegee function so you can do all the nitty-gritty jobs around the house including the windows in no time and no elbow grease at all !!
Aug 12, 2010 | Microwave Ovens
We have a Haier upright freezer and i can not get the alarm to go off
the reason there is no fan on the outside is because the outer shell of the unit is the condenser. the unit does it have a fan on the inside? also how does that gfasaket on the outside of the door look like? let me lknow
I would leave the door closed unplug it for half an hour. In that half hour go to sears.com customer service, manuals and guides and type in the full model number from the freezer. You should find an owners manual there to print or just browse for an answer. Good Luck.
Jul 06, 2010 | Microwave Ovens
AMANA UPRIGHT FREEZER LEAKS WATER FROM THE DOOR
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 14, 2010 | KitchenAid Architect II KBHS109SSS...
Need roller guide for Welbilt microwave model MR626T w/turntable - can u help?
Welbilt was sold to Haier Corp. So maybe this works:
Contacting Welbilt Phone (Haier): (877) 337-3639
Mail:
Haier America
1356 Broadway
New York, NY 10018
USA
Nov 17, 2008 | Welbilt MR626T Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
