Question about Lexmark X4270 All-In-One InkJet Printer
I have a Lexmark All-in-one X5490. Color Cartridge replacement request
I have a Lexmark All-in-one X5490. I get the "Color Cartridge replacement request" message after I remove and put it back, but it is not empty, even half level ink! How can I reset the NVRam?
  • Anonymous Apr 26, 2009
    Same **** but with a lexmark 2600... Lexmark is... not what it used to be. I'll not be buying from them again after a lowbrow marketing ploy like this. Hope everyone else who is getting ripped off like this does the same and puts them out of business. Money is too tight to tolerate under the table BS designed to exploit an uneducated user...
    Genius:
  • 2,035 Answers
Printable Version I have a Lexmark All-in-one X5490. Color Cartridge - print_friendly.gif I have a Lexmark All-in-one X5490. Color Cartridge - null.gifimg src="http://i.fixya.net/uploI have a Lexmark All-in-one X5490. Color Cartridge - null.gifes/null.gif" alt="null.gif" class="h_mi" /> nuI have a Lexmark All-in-one X5490. Color Cartridge - null.gifclass= How to Clear the Memory on the Lexmark X4250 / X4270 ID:ENUS13874 null.gif null.gif null.gif
  1. Disconnect the power cable from the back of the printer.
  2. Hold down the Stop/Clear button.
  3. While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
    Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
  4. Select the personal settings you require as follows:
    LANGUAGE? Press the right arrow key to select the language you want to use, and then press Select.
    COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
    ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
    ENTER TIME: Using the format hh:mm, press Select.
    Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
PERSONALIZE FAX: Press Select.
Enter Name: Type in the name and press Select.
Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
Posted on Apr 18, 2008
Did you have any luck with your lexmark x5490 ink problem? as i have the same problem you had, did you find a solution and can you help me.
thanx
Posted on Oct 15, 2008
HOW DO I INSTALL MY LEXMARK X5490 PRINTER TO MY LAPTOP IF I DONT HAVE A DISC?
Download the LEXMARK X5490 PRINTER DRIVER from this site:
http://www.siliconguide.com/drivers/device/980/
Sep 13, 2011 | Toshiba Computers & Internet
Printer is not working new ink
Cartridge World stores have a 100% satisfaction guarantee; they will repair, replace, or refund any cartridge you find unsatisfactory. You need to go to the store you purchased this cartridge from and request a new one.
Sep 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Cannot overide "wrong cartridge" message when using oem cart
Lexmark International does not recommend the use of third party inks or inkjet cartridge refill kits. Genuine Lexmark inks and cartridges are perfectly matched to the printing system. Using genuine Lexmark ink and cartridges ensures that every document produced is of the highest possible print quality, providing long-term dependable service from your Lexmark printer.
Lexmark cannot assure the excellent print quality and reliability of its inkjet cartridges after a cartridge has been refilled. Using incompatible inks in an attempt to extend the life of a genuine Lexmark cartridge beyond its recommended usage can cause failures in several different areas of the printer. Inkjet cartridges and printer failures caused by refilling or a third party ink are not covered by your Lexmark printer Warranty, Extended Warranty or Service Agreement.
Please use genuine Lexmark cartridges for best results.
Apr 13, 2009 | Office Equipment & Supplies
Lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Feb 13, 2009 | Lexmark X4530 InkJet Printer
"color cartridge replacement required"
This is common problem with lexmark cartridges they detect refilled cartridge you need to clean the copper contacts of the cartridge and then insert it if it still shows " color cartridge replacement required" message then you need to buy original color cartridge.........
Jul 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
My lexmark X1185 all in one printer will not print color.
did you make sure that you pulled all of the tape off the bottom of the cartridge. next recheck your settings. they will not return to normal themselfs
Jun 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X4270 All-In-One InkJet Printer Logo
1,066 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
