Question about Xerox Phaser 6130 Laser Printer
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
Our Xerox Phaser 6130 is stuck in 8.5x11 paper mode. We have everything set in A4. Clearing the print cache doesn't help. Neithe does turning the printer off for 5-10 min.
    President:
  • 2,072 Answers
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Posted on Jul 09, 2010
Testimonial: "This solved my problem. Didn't have to pay for a repair call and didn't have to pay $50-75 for online help. Thanks"
  • Rick Kasper Jul 13, 2010
    Glad that was it.
    New Friend:
Thank you so much!!!! It worked for me too!!! :)
Posted on Nov 09, 2015
My phaser 3040 xerox printer says there is a paper jam, but there isn't
I suggest You Go to Official Xerox Printer Page For You Xerox Printer Problem On Below Xerox forum URL Link: Clearing Paper Jams In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Xerox Printer Support
Feb 27, 2014 | Xerox Phaser Office Equipment & Supplies
The secretary ordered 3rd party toner cartridges for a Xerox Phaser 6130. After replacing the black cartridge the "invalid cartridge" message comes up. Is there a way that we can use the 3rd...
If you get the "invalid cartridge" message, try completely turning off and unplugging the unit. Then remove the cartridge, close the door and after at least 30 seconds, restart the unit. Then reinstall the cartridge. This worked for me!
Sep 26, 2011 | Xerox Phaser 6130 Laser Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
How do you use photo paper in a xerox phaser 6250?
If you want to use photo paper for your Xerox phaser make sure the photo paper is meant to be used in your printer. The best paper would be the Xerox brand photo paper which is made to be used in the Xerox phaser printers. You use them like normal paper and print your document or image onto the paper. If you cannot find the paper that works with this xerox printer go to the Xerox website and under supplies, then entering your printer model it will give a list to the paper recommended for this model.
May 27, 2010 | Xerox Phaser 6250 Laser Printer
My xerox phaser 6130 prints only in black
Check if the color cartrige is properly plugin in the printer
Dec 07, 2009 | Xerox Phaser 6130 Laser Printer
Xerox 6130, prints black very light. Replaced two
I think your Image Unit is going bad. Order this PN 675K69244...That should solve it.
Whit
Item, Inc.
Oct 23, 2009 | Xerox Phaser 6130 Laser Printer
Xerox phaser 6130: machine is about 2 months old,
Have you checked the Xerox support site? If not, try these links for your printer
Documentation
Drivers
Product Support
Troubleshooting
If this helps, click YES below.
Jun 30, 2009 | Xerox Phaser 6130 Laser Printer
Black printing is very dull but colors are bright in Phaser 6130
I have the same problem with a 6350 Phaser. Did you get it fixed?
Jun 11, 2009 | Xerox Phaser 6130 Laser Printer
How to refill xerox phaser 6125?
Just found a supplier for toner and reset chips for my new 6125. Don't know where you're based but in the UK you can use the following link:-
http://www.zinetic.co.uk/Xerox_Phaser_6125_Toner_Refill_Rainbow_Pack-details.aspx
In the US, a possible source from EBAY is:-
http://cgi.ebay.co.uk/4-Xerox-Phaser-6125-6125N-6130-6130N-Toner-Refill-HY_W0QQitemZ380126889100QQcmdZViewItemQQptZBI_Toner?hash=item588154048c&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Good luck.
MJN
Apr 07, 2009 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6130 Laser Printer Logo
390 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
