Question about Garmin nuvi 250W GPS Receiver
I would like to upload the maps of the Santos gas wells in the Cooper Basin. I just started working in the Basin, and have to go to all the different wells to repair them. It would be easier to use my Garmin nuvi 200w/250w gps unit
  • 677 Answers
Hi, you will get to germin.com to upload the map you are looking for.
The site will guide you to what ever you want.
Take care.
Posted on Jul 07, 2010
What areas of the u.s.a. are lower than 4000 feet above sea level
These links should help you out. 4,000 may be too specific, but I hope you get a good sense from the links.
Geography of United States Low Points
List of places on land with elevations below sea level
Also an FYI;
Badwater Basin is an endorheic basin in Death Valley National Park, Death Valley, Inyo County, California, noted as the lowest point in North America, with an elevation of 282 ft (86 m) below sea level. Mount Whitney, (with an elevation of 14,505 feet (4,421 m)) the highest point in the contiguous 48 United States, is only 84.6 miles (136 km) to the north west.
Feb 02, 2015 | Miscellaneous
Google maps
well, there is no GPS on that model. and the only way to get any applications on your phone is to add them with a WAP uploader. So you need to download to .jar file for google maps onto your computer and then use the wap uploader (just type that in google and you will find one) to upload your file onto your phone. good luck.
Apr 28, 2013 | Samsung Star GT-S5233 Cell Phone
Need to know where exactly is the IAT/MAF sensors on a 2004 Mini Cooper
You have a IAT and a MAP there is no MAF(Mass air flow).The MAP and IAT are one unit cansmo_12.jpg
Sep 13, 2011 | 2004 Mini Cooper
Will not show transferd maps will show routes that have been sent to it base map showing
Go to the SETTINGS menu and select the MAP INFO menu. Make sure that the check box by the uploaded map that you want to use is checked. If the map is not checked, then only the base map will appear. This allows different maps to be installed simultaneously.
Jul 29, 2010 | Garmin Quest GPS Receiver
1999 4.3 vortec map sensor removal & install, does it just pop out? not sure if its the problem,starts and idles fine, push on the gas and it starts to rev than cuts out, bogs down, let go of the gas...
Could be several different problems things causing this,Disconnect map sensor and try pushing on gas if map is bad problem will be gone or different,you could also have TPS sensor,Distributor problem,or fuel volume problem,Are there any codes set?
Oct 31, 2009 | 1999 Chevrolet S-10 Pickup
Starts but won't run
Sounds like fuel vapor lock. When fuel is heated, it will change from liquid to gas.... gas bubbles don't feed very well through injectors or throttle bodies.
Inspect your metal fuel lines under the hood, most likely. See if a metal hose is touching the engine, especially the near or on the exhaust manifold. You might want to insulate the fuel lines (Lowe's or Home Depot $4) with pipe insulation.
Sep 26, 2009 | 2005 Mini Cooper
I just purchased the Map update 2009 dvd. I installed everything and the computer said everything was downloaded. I restarted my garlin and it doesnt appear that anything is different then when I...
The only way you can be assured that your map update was successful is to check the version.
1) On your main screen, you'll have a little wrench tool, click on it.
2) On the next screen, go to the "Map" icon.
3) Next screen, click on the "Map Info"
4) Last screen you'll see the maps isntalled and the year.
Best of Luck!
Apr 10, 2009 | Garmin StreetPilot C330 GPS Receiver
How to upload maps in garmin 200w from sd card
on menu touch tools, maps, map info, tick the box, you may need unit I.D. and serial number.
Regards.
Mar 21, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 610
500Mb internL MEMORY ONLY- LOAD MAPS TO SD CARD TILL 4 gB WORKING
Oct 27, 2008 | Garmin Nuvi 610 GPS Receiver
Problem with uploading Map Update 2008
"Isn't it supposed to look like the image on the package? "
NO, the image on the package is just for show. The newer Garmin C5XX, Nuvi, will allow you to change to a car icon. To get 3D go to the main menu and select the wrench, then select map, then Map view to change to 3D.
Mapsource 2008 only upgrade the streets and POI (point of interest).
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
13 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
