Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Pump not working. I can hear it running but no water is moving through the hose.
  • Intex Master
  • 8,404 Answers
Replace your impeller ...
Posted on Jul 06, 2010
Amana nfw7300ww00 wont drain. pump basket is clear pump runs but not pushing the water out. pump hose is clear
You may have blockage up b4 pump need to remove hose from outer tub and clean out or pump is bad and just spinning motor you hear prop is stripped
Jan 30, 2013 | Amana Washing Machines
Windshield washer not working. No water spray
I'm assuming you can hear the pump motor run, the resevior has washer fluid in it, but there's no spray... correct? Then the problem is most likely a clogged pump inlet screen. You will need to access this pump/resevior from the right hand side wheel well (liner moved out of the way) and disconnect the wiring connector at the pump & the rubber hose at the pump housing. This particular pump is 'snapped' in place with plastic holders as part of the resevior housing and a rubber grommet where the inlet tube of the pump is inside the housing. Once you remove the pump, the inlet screen can be removed & cleaned. You'll also want to flush out the reseviore to clean it. Refill with fresh water & W.W. solvent after you reinstall the pump after cleaning the screen. Reconnect the hose and wiring connector to the pump. before refilling.
Sep 05, 2011 | 2006 Hyundai Sonata
Does not pump water away code LE
Do you hear the pump running? If so, the problem will be a blockage. Either inside the machine at the water outlet, at the pump or more likely in the outlet hose. Endeavor to ascertain that the outlet hose is completely clear.
If you do not hear the pump operating the problem could be either the pump or the electronics that drive the pump.
Dec 28, 2010 | LG Dishwashers
My Kreepy Krauly works for 10-15 minutes and then stops hammering and sits on the pool floor. I have replaced and checked parts and the pump runs well.
you may have a hose that allows air to get sucked in at times when the unit moves and the hose with crack is able to float to the surface and make contact with outside air. move hoses around and see if that helps you can also start from the closest connection at the suction port and lift the hose out of the water one section at a time hold it out of water for a moment and see if you notice any weird feeling or hear a slurping do this section by section until you get to the last hose section at kreepy head
May 14, 2010 | Pentair Kreepy Krauly Inground Automatic...
My washing machine wont drain water
Do you hear the pump running when it is supposed to? If no and the machine is still under warranty, take advantage. If you do hear the pump running, but nothing comes out--lower the drain hose down near the floor to see if it will gravity drain into a bucket or pan. If it drains, then the pump isn't moving anything even though it is turning--it must be replaced. If it doesn't drain freely, then something is blocking the drain--a pinched hose either to or from the pump, or maybe a stray sock blocking the outlet from the outer tub. The last item usually isn't considered a warranty problem. Hope this helps!
Mar 28, 2010 | Tecnik TKL9260 Front Load Washer
Kreepy Krauly is not moving at all. Air bubbles are visible at return into pool, but water pressure is very low. When system is put on circulation, the return is much stronger than on filter. No visible...
If circulation is better when you pull the cleaner from the water the problem may be in your hose's. With the pump running pull the hose's from the water one at a time to see if you hear air leaking into the hose's and then replace the bad ones. Hope this helps, good luck
Dec 02, 2009 | Zodiac Pacer Pool Cleaner
Cooling system requires burp.
A large air pocket can sometimes be tricky to get rid of. The easiest way is to jack the front end up in the air with the wheels off the ground and support with jack stands, remove the radiator cap(make sure engine is cool) and allow to sit over night in this condition. The elevated front end will allow the air pocket to move to the most highest point and then escaping out the top of the radiator, after doing this procedure make sure to inspect coolant level in radiator and overflow reservoir and top off as needed.
Apr 07, 2009 | 1997 Dodge Ram
Dirty water runs back into washer, moving drum, you hear it.
What kind of washer. Most washers will have a balance ring in them. This balance ring has liquid sealed inside it. So you will hear water swishing when you move it.Totally normal. If water is indeed running back into the tub, you need to pull your discharge out of the wall. It should only go in about 2 ft max. Any deeper and you can get syphoning. Dave www.washermd.com
Jan 13, 2009 | Washing Machines
Front load washer not draining
If the water is not draining the firt thing to check is the pump. take the 2 screws off the front bottom panel and remove it. get a bunch of towels or a wet dry vac ready. the pump should be on the right attatched to the drain hose and the coin/debris cather(a black rubber bladder. Remove the drain hose (use pliers on the clamp and pull the hose off. A lot of water will come out as well. Remove the rubber bladder(coin catcher) clamp with a philips head screw driver and pull it off the pump.Un plug the pump remove the monting screws. Check the pump and the bladder for debris. Look in the pump and make sure the impeller is not damaged. spin the impeller and make sure it moves. if the impeller is damaged then the pump need to be replaced. Assuming everything seems ok reassemble and run an empty load with the dial set just before final spin. If the pump is working you should hear it, and possible feel water moving through the discharge hose.
Mar 25, 2008 | Kenmore 44102 Front Load Washer
Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Mar 20, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
83 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
