Question about Refrigerators
The overflow tray at the back of the fridge smells and is full of dirty water/milk, how do i clean this, does it come off
  • 25 Answers
Hi; Try using hot water and a bit of Elbow grease. Also you may find adrain hole hidden in there aswell, that may need a good clean. At the back(rear of fridge onto of the compressor.Black metal Thing) there should be a plastic hat, see if water goes onto that from the drain hole in the fridge. If that happens the drain is clear
Posted on Jul 06, 2010
Can't clean out spilled (and now sour) milk spill
Hi, I'm not familiar with these fridges, but is it possible to access it from the back, underneath the evaporator tray? It could even be that the milk has gone down the drain hole and into the evaporator tray itself. Its a small flat plastic tray that has raised sides, and will probably have water in in, sits just above the motor
Dec 27, 2013 | Viking Refrigerators
My evaporation tray is full and smells as milk has split into it and gone off -it is making the kitchen smell. Does the evaporation tray unattach from the back of the fridge?
if you can get to the tray pour in some clorine bleach,or pour some down the drain hole,this will kill any smells/bacteria.(works with all fridges).
Jan 11, 2011 | Zanussi Refrigerators
I have a Haier HRD-211 HP5 direct cool fridge. Last couple of days the air around the fridge is smelling like spoiled or sour milk - no smell inside or on the body of the refrigerator and cooling is fine...
Check the defrost water evaporator tray located inside the bottom grille. You probably will find a disgusting mess. Remove the tray and scrub it clean to resolve the problem. While you are cleaning up, check the tube that directs defrost water into the tray. It may be clogged.
Jul 02, 2017 | Haier Refrigerators
Evaporation tray at back of stand alone refridgerator is full of .....? and smells. How do I clean it as it is fixed to the back of the fridge?
syringe out drain hole/pipe with clorine bleach(clorine will gas off and leave no smell after an hour or so)clean out tray with bleach,as it will kill the bacteria that causes the smell,the higher the himidity the more often you will need to clean drain/tray.(any clean water in tray ,use to feed your house plants,
Aug 04, 2010 | Zanussi Refrigerators
Smell from fridge back because of milk leakage
the bad milk smell got into the drain pan if you look next to the compressor there is a drain pan you need to clean it. and also the pip that go from your freezer to the pan.
not so hard to do but will make sure the small gone.
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
My Matsui under counter fridge smells of old milk/veg really badly despite cleaning out thoroughly including catch tray at back and downpipe. It is only 1 year old - any advice gratefully received
Can you pull out the fridge and check that the plastic power cable has not been pressed against the compressor at the rear/bottom of the fridge?
Usually, overheated plastic cable smells like rotten veg!
Nov 17, 2009 | Refrigerators
We have a Meile fridge freezer and the smell seems to be coming from the back (no smell inside)It has been a constant smell but occasionaly gets worse. It has taken us a week to find out that its coming...
Self de-frosting tray at the back of the fridge was full of old stagnent water. Removed tray cleaned out, flushed out the pipe from the inside of the fridge to the drip tray. No more smell.
Nov 02, 2009 | Refrigerators
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Bad smell from vent at back of fridge but able to remove back panel
if you cant remove it then wash it unplug the refrigerator from ac outllet first then remove the carton cover in the back and you gona see the pan were the water is temporaly storege with a garden hose washing the pan and then clean the floor use or news paper around the refrigy is helpfull the water or so in the pan is evaporated with the hot of the compresor sistem that water come frome the freeser compartment....good luck and rate me
Jan 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
