Question about Carrier 38CKC060 Air Conditioner
I have a carrier 38ckc060370 that runs but the air is not cold coming out of the vents. i checked the copper line coming out of outdoor unit and is not cold either. does this mean that i need a recharge, or could there be some other problem? recently, i've had problems getting the unit to turn off, and had to use the breaker because it would not shut down on its own, but other than that, the unit has never had a problem. the unit is about 4 years old.
  • epelote Jul 07, 2010
    thanks for the detail. I had someone come and take a look and it needed over 7 pounds of recharging to get the thing working again. everything else seems to be working fine, but the thing was running on empty. not sure why or how it even worked last week. probably have a leak somewhere.
    thanks for your time since it helped to find someone since i had an indication of what my specific issue might have been.
    Novelist:
  • 117 Answers
If the unit is not shutting down, then there is a chance the contactor has gotten stuck. This is not a good thing. If the contactor were to weld itself shut and the outdoor unit were to continue to run without the indoor fan running for an extended period of time, the compressor could be damaged from the floodback of refrigerant to itself.
Feel the air coming out of the top of the outdoor unit, it should feel warm to hot. The copper lines- the smaller of the two should be warm and the larger of the two (should be insulated) should be the cool one...not necessarily really cold....
If the copper lines are both the same temperature, its an indication the compressor is not running. This may be a bad contactor, a failed capacitor, or the compressor itself may have a problem with it.
If you can get the system running, it would still be best to have it checked out and looked over. There may be underlying problems that are creating the problems you are currently experiencing and its always best to find the root cause or problem rather than the smaller issues that just cover up the real problem.
Posted on Jul 06, 2010
  • epelote Jul 06, 2010
    the continuous running may have been due to low batteries in the
    electronic thermostat. it now shuts off and on whenever we turn it off
    or on. The air coming out of the top of the outdoor unit is neither hot
    nor cold. just like i have a really great fan blowing. The copper lines
    are basically air temperature although the small one i think was a little warmer to the touch than the large one, also neither hot nor cold, so it could well be as you suggest. Is there a chance that it could be that the system just needs to be recharged with coolant?
  • Bill Jul 07, 2010
    The system may need to be recharged. But most likely the compressor is not running. You can typically hear the compressor running and touching the copper lines is a better indication. The larger line will be much cooler than the outdoor temp. The smaller of the two will be warmer than the outdoor temp....If they both feel the same and are close to the outdoor temp, the problem is most likely the compressor is not running.
    The compressor may be bad or the start components for the compressor may be weak or failed. Without a multimeter that can check the capacitors, its really hard to determine the actual problem at hand. If you open up the outdoor units electrical panel, you will see the capacitor(s) within the unit. They are cylinder shaped and are typically either silver or black. There is a chance, depending on your specific unit that it may have 2 capacitors, one being a start capacitor and the other a run capacitor. You could attempt to replace the capacitors first to see if the problem is there...but you will need a multimeter to do and involved troubleshooting.
AC not giving cold air
Kindly check outdoor unit fan Motor running or not . and it may possible blockage in the copper tubes (/capillary)/.need to internal clean by nitrogen flushing.
Jul 26, 2016 | Carrier Heating & Cooling
My carrier 38CKC (60) is blowing hot air. The fan seems to be running fine. Is it the condenser coil, or just needs freon? How do I know? The unit is about 8 years old and never been serviced (I know...I...
Assuming the outdoor unit is running, make sure the fan motor on top is turning and the compressor is running. They both must operate for the unit to function.
The easiest and most common problems:
1. Condenser coil is stopped up with dirt. The condenser coil is the radiator looking coil that wraps around nearly the whole outdoor unit. It can be washed out with water and a sprayer, just make sure you don't bend the aluminum fins and disconnect power before washing it out.
2. Low on refrigerant. If you don't have guages you can't check the refrigerant on your own. If the fan and compressor are running , feel the bigger copper line coming from the outdoor unit going into the furnace. It should be cold. If not you can either be low on refrigerant or the compressor valves are weak.
Hope this helps. If the unit is not running outside, repost and I will try to diagnose differently.
Jun 16, 2011 | Heating & Cooling
Carrier air conditioner isn't cooling the house. It is blowing air, but it doesn't seem to be cool air.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Jun 24, 2010 | Carrier 38CKC036 Air Conditioner
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Can't seem to get the compressor to come on. When
hi how are you...you say your outdoor unit is not working...is thermostst set in heat or cool when this is happening....if the compressor is running,go outside put your hand on the big copper line,if it is hot,your in heat mode,if it is cold your in cool mode..is it heatpump or ac only...if ac only ,you have a sequencer stuck ,or contactor closed keeping heat on...please chek items first...michael doctor airr appl.repair 843-384-8474...if need help call,ill help talk you diagnosis of problem...
Mar 27, 2010 | Carrier 38CKC060 Air Conditioner
Hi i have a lg split system air con model number lst243h-2 its nice and cold when i first turn on then its just like the fan is on its not cold at all
How long before it goes from cold to hot. The compressor could be not running and going out on overload. The condeser fan could have failed. Did you check the outdoor unit. Is it running? Is the fan running on the outdoor unit. It could be low on charge which would cause ice. Are you getting excessive condensation? Let me know and i can help you out more. Grab the large copper line outside that is insulated and tell me if it is cold. It should be cold like a Pepsi out of the fridge!
Aug 23, 2009 | LG LSC183VMA Split System Air Conditioner
RUUD Silhouette II
You will need to let the indoor fan run for several hours to defrost the indoor coil. it may take 12 hours to defrost you'll know when it's clear when the vents are blowing like usual again. Then run the unit for 5 minuits and check the large copper insulated line going to the outdoor unit. is it cold? if not you need a refrigerant charge. If it is then make sure never to run the unit below 70 degrees and check your air fliter and return duct for blockage of possible collapse. Also you may have a dirty indoor coil chac that and clean the outdoor one as well.
Oct 05, 2008 | LG LM-2430C2L Cool Mini Split Air...
Central air unit
Make sure you let the blower run for a while after it freezes to make sure there is no more ice. Then run the unit. Check the refrigerant lines the large copper line that has insulation on it should be cold to the touch. If it runs for 10 minuits and is barely cold or warm you are low on refrigerant. If its starts out nice and clod then check your filter and retun ductwork for blockage you should not have noisy return air vents or that can indicate you have too small a return.
Also are the outdoor unit and indoor coil a match? Same tonage?
Is the furnace big enough to handle the tonage? (fan size)
Aug 17, 2008 | Coleman Propane Forced Air Heater...
Central Air not cooling properly
This tubbing carries the refrigerant. The small line is flowing to their inside air handler. If the line is hot it is an indication that the outside unit is not able to release the heat. The most common reason is that the coil (looks like a car radiator) is dirty or plugged. This can be cleaned with a brush or sometimes a garden hose. They do make acid type cleaners for doing this, but the use of the acids are restricted in some areas.
By the way the other black pipe should have a larger copper line behind the black insulation. That line should be cold and sweaty like a nice glass of ice tea:)
Jun 26, 2008 | Carrier 36KCARMS Air Conditioner
Carrier 38CKC060 Air Conditioner Logo
326 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
