Question about Intex 4000 GPH Filter Pump
My key pad qweruiop is not working i am using a virtual keyboard
    Problem Solver:
  • 5 Answers
This keyboard problem has been solved. Look at the following link:
http://www.techbuzz.in/keys-qwer-uiop-not-working-rest-other-keys-are-working-fine-laptop-desktop.php
Posted on Oct 10, 2010
One Key, the Scandinavian o with a slash, is very slow after installing Windows 10
Are you talking about this ?. If so a trick to input it is to hold down the ALT key and press 149 on the numeric keypad. You can input all sorts of symbols, check out this list.
http://www.alt-codes.net/
May 01, 2016 | Microsoft New 200 Keyboard Wired Black Usb...
The qweruiop keys stopped working at the same time any ideas how to get them working again? thanks
There could be something under the keys or maybe you just hit them to hard and the button might be stuck or the sensor might not be working.
Sep 02, 2013 | HP Computers & Internet
How To Unlock The Music Pad ? If The Music Lock And Unlock Key Is Not Working
You can download this software I use it for my W610i the keyboard doesn't work at all so this software can synchronize your phone info, also has a feature that you can use virtual keys to use your phone, it's a great help when this kind of issues happens.
Nov 22, 2011 | Sony Ericsson W350i Cell Phone
The digital keyboard will not pull up from the bottom. I have to use the actual key pad to communicate. Have any idea what the problem is?
Try tapping the text field where you want to type a few times. If that doesn't work, check your settings by going to:
Settings > Language & keyboard
Make sure one or more virtual keyboards is checked in that menu, if they are all disabled, you can only use the hardware keypad.
Mar 01, 2011 | Motorola Mobility CLIQ Cell Phone
Which is an function key in keyboard
(FuNction key) A keyboard key that works like a shift key to activate a second function on a dual-purpose key. Commonly found on laptop keyboards, the Fn key is often used to control hardware functions such as screen brightness and speaker volume. The Fn key may also be found on extra small keyboards for desktop computers, typically for Page Up and Page Down, which are combined with Up Arrow and Down Arrow. See function key.
Feb 24, 2011 | Samsung Pleomax PKB-700B Keyboard
QWERUIOP Don't work, I have purchased a new keyboard, but as expected it is the same. I had this problem once before, and did fix it, but I can't remember how. I needed a new keyboard anyway, as the...
This happened to me on my NEC Versa M300 so I took the keyboard off and swapped it for my brother's (we have the same laptops) and the replacement one works fine. I think a terminal on the connector gets dirty or corroded.
Mar 10, 2010 | HP D8597A Keyboard
Keys qweruiop not working on startup (first 15 minutes or so) on physical keyboard on HP G60-533CL Notebook PC running Windows 7 Home Premium (64-bit). Keyboard Driver Standard 101/102-Key or Microsoft...
Take the computer to a qualified technician, who can replace the keyboard, as the least-expensive "try" at trouble-shooting.
Since a keyboard transmits "codes" to the motherboard,
e.g., left-shift-has-been-pressed, and left-shift-has-been-released,
and the motherboard interprets those codes, it is NOT likely that
the motherboard is misinterpreting the codes, especially given that
the "bad' letters are in a straight line on your keyboard.
Find an external USB keyboard, and plug it in.
If it works correctly in the first 15 minutes, then the problem is NOT the motherboard.
Jan 04, 2010 | HP Computers & Internet
LifeBook T4210, some letters ont the keyboard doesn't work
hello
Some of the letters stop working due to dust that stuck between the pad and board..Or due to degradation.
So you can try cleaning the keyboard with vacuum cleaner and clean properly between the keys.
If the keys still don't work you can replace the keyboard as it is replaceable.
Thank you
Jul 13, 2009 | Fujitsu Siemens LifeBook T4210 Notebook
JUST HLP PLEASEEEEE
Sounds like your keyboard is sticking
Unplug the keyboard and do the following
Look on the bottom you should see some screws, remove the screws and leaving the keys facing down, pop the two pieces apart.
Leaving the electronics aside you can now continue with the following instructions
Ok, once you have the two pieces, all of the keys should stay in there proper place, take and soak that in the sink with some soap and water.
Moving all the keys to get the water to flow through.
Then dry off the Keyboard and vacuum all the excess water off, then replace and screw back together, you should be good to go.
I wouldn't recommend a dishwasher, this could get to hot and melt the keys
Apr 24, 2009 | Gateway 2520796 Keyboard
Intex 4000 GPH Filter Pump Logo
751 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
