Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Segate portable hard drive 500 gb not able access
Try to boot your Hardrive to the other computer ( hard disk to hard disk) and you can access your folder and to back up your files...if try to and then don't forget to scan your harddrive, format your hardisk in your motherboard...check also your motherboard if working properly...if no work at all...your Hard disk is collapse it because of service factory defects///.... :D
Posted on May 13, 2012
  • caballerojan May 13, 2012
    try to boot your Hardrive to the other computer ( hard disk to hard disk) and you can access your folder and to back up your files...if try to and then don't forget to scan your harddrive, format your hardisk in your motherboard...check also your motherboard if working properly...if no work at all...your Hard disk is collapse it because of service factory defects///.... :D
  • 518 Answers
Is the computer see ing it if not ,unplug run computer then turn off re plug in and computer should see it with its plug and play system
Posted on Jul 06, 2010
2 Suggested Answers
  • 67 Answers
SOURCE: my segate expansion portable drive
According to your problem, check the viruses of your hard drive. Check the cable of the hard disk. Make sure that the drive is OK. Check also that the portable harddrive's file format supports the PC file format.
Posted on Jun 06, 2011
Is seagate Barracuda 7200.12 500 gb hard disk pc board is same as 350 segate board
They could be electronically and physically the same but I do not think the firmware is the same hence it will not work properly.
Apr 26, 2014 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My segate expansion portable drive 500 gb not work from my pc
Has it worked in the past or is this a new drive?
if this is a new drive, make sure it's connected to yout computer and installed (there may be some drivers that are required from the vendor - perhaps on cd/dvd)
Also, you may need to format the drive in order for it to work.
Jun 06, 2011 | Computers & Internet
Instructions or Users Guide
Here is an extedend FAQ for segate disks, on how to backup files on different operating systems:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=204731
Mar 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My segate hardisk 160 GBhas been dead
why don't you try www.247servicecenterinfo.com, they have listing of all SEGATE service centers in india.
Jan 19, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Segate FreeAgent 750GB external hard drive
my iqube extenal hard drive is not working was dropd down, I have tryed plag and play and it shows the light and fun inside working and when you staart uyou can ear like its start but stops after few seconds
Oct 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
126 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
