Question about Microwave Ovens
The microwave switches on but the food does not heat up at all even when on 100% power.
  • 3,600 Answers
You need to replace the magnatron bulb but need the model number to give you the right bulb number and how to replace it, normally there are two screws in the back of the oven and the bulb is located in there some are on the inside, you can go to http://www.appliancepros.com to find your unit and a picture of where it is.
Posted on Jul 06, 2010
No heat from my microwave
It's a major problem. The component that produces the microwaves has ceased to function. You may have a warranty fix available.
Nov 14, 2013 | Advent MW912BK Black Built-in Microwave...
How to set power settings
Set the time as you normally would to cook your food: i.e. 60 seconds. Hit the power button; 100 will pop up on the screen, as in 100 % of power, enter 50 for 50% power, 70 for 70% etc. Food will cook more evenly this way, not burnt to a crisp on the outside, cold in the center.
Mar 13, 2013 | Rival Rgst902 Microwave Ovens
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
The microwave runs and sounds normal, but it does not heat up the food. (We did run it at 100% power a few times, with no heat up) Do you have any suggestions to what the problem could be? We purchased...
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. you said your unit has power, and things lite. Then it is more likely you have a control/switch problem,
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Kenmore 63252 Microwave Oven
Oven won't heat food
Bad Magnetron. Unfortunately, and especially on high power microwaves, magnetrons do die. They'll probably run you between 100 and 300 dollars to replace. If you believe that your microwave is within warranty(not likely), contact the manufacturer for repairs. Otherwise, it may just be cheaper to purchase a new microwave.
Sorry that this answer doesn't produce a happy result, but it's an unfortunate fault of microwaves as a whole.
Apr 23, 2010 | Maytag MMV5186A Microwave Oven
Microwave Won't Heat
Check the door safety interlock switches. Be careful of the capacitor, potentially dangerous.
If the switches dont make a connection, the magnetron will not energize ... no heat
Apr 19, 2010 | Microwave Ovens
The microwave will light up, the buttons work, but no heat to cook food
Your magnitron tube is out (it makes the micro waves) If you are handy you can switch it out for around 100-150, go to marcone.co to get the new mag tube
Nov 11, 2009 | Frigidaire FMV156DC Microwave Oven
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Cuisinart Microwave won't heat food
open the casing and replace the blown fuse.there are several so check them all. probably why the machine was in the auction
Feb 05, 2009 | Cuisinart CWM-100 Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
