Question about Motorola Mobility RAZR V3
Resetting I dont know what the security code is to the master clear and i am trying to reset a verizon motorola razr. thanks for the help
    Sergeant:
    Champion:
  • 283 Answers
Try this if you dont put anycodes in your fone...( 000000 )
Posted on Apr 20, 2008
How to remove message saying "emergency calls
If "Airplane Mode" is activated, this could happen, otherwise there's no other settings to deactivate or activate the offline mode with this Model. The "Airplane Mode" is under Settings, make sure it's Off.
You can also check the Network Setup under "Settings" and make sure "Automatic" is selected.
I would also recommend you to try with another sim card. If the same problem persists with another sim card, try resetting the phone "Master Reset". There are two options to reset your phone, 1. Master Reset and 2. Master Clear. Master Reset will reset every the phone settings to factory default while Master Clear will reset the phone as well as clear all the data from the phone and will restore everything as it was when you bought (as a new handset).
To do Master Reset, open "Settings" then "Initial Setup" and "Master Reset", you'll be asked to enter the security code, type in 1234 and proceed, if 1234 doesn't work, then use 000000 (6 zeros).
Note: if you have changed the code, you should use that.
Even resetting doesn't help, then there must be Network Problem with your phone, perhaps, the Network IC. In rare cases, Antenna causes this issue. Or sometimes it's related Software. All these are to be checked/done at Motorola Service Center or at local Mobile Repair Shops.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Master reset code master clear code
You may try default phone and security code to remove restrictions
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
ur defalt phones codes is 12345 or 00000 u can use it
type *#06# on your phone to get it.
Sep 03, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Motorola master reset code
Master reset code is 0000 is the default code. Either 1234 is the code.
Nov 09, 2008 | Motorola Mobility RAZR V3
Forgoten Motorola Ming A1200 Master Reset Security Code
Have you tried inputting all zeros for the master code (00000) I think it is 5 - 0's but it might be 6 (000000) I think this is a master code. Give it a try..
Jul 24, 2008 | Motorola Mobility RAZR V3
How do i reset my Verizon Motorola Razr Silver
If by "reset" you mean you want to clear out all of the info and put all the settings back to factory defaults, then go into the settings menu, select initial setup, then go to master clear. It will ask for a security code. It should be six zeroes (000000). This will erase everything on the phone- contacts, texts, etc.
Mar 12, 2008 | Lands Phones
Security code
You may try to reset codes on new motorola phones with following commands through phone keyboard.
Put phone in Test mode - 048263* (Push the key quickly!)
you should see this message: "Opcode", 'Cancel' "Okay'
After Putting t phone in test mode then use following commands
to see or reset security code.
User code -> 32*116*1*0*0
Security code -> 32*118*1*0*0 Master Reset -> 18*0
Master Clear -> 18*1 ----
* is Asterisk key on the phone keyboard!
http://www.gsm-unlock.com/unlock/unlock-motorola.html
Additional info:
Default 6 Digit Security code: 000000
Feb 03, 2008 | Motorola Mobility RAZR V3
Motorola razr v3m from verizon
I think it is best to have them exchanged the phone...but try doing a master reset and master clear
Dec 19, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Messed up fone
try master reset or master clear
Sep 21, 2007 | Motorola Mobility RAZR V3
TEXT SCREEN FREEZES
T-Mobil master reset is 000000 (6 zeros)
Sep 16, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
286 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
