Question about Maytag M6Y12F2A Air Conditioner
AC window unit pops circuit breaker
My Maytag Air Conditioner keeps popping the circuit breaker. The unit is 7 years old and I noticed that the cord is getting warm when the unit does run. I did clean the filter thinking that it had enough dust buildup to block air flow. What are some trouble shooting ideas I should try or is there a more drastic problem that I should be aware of?
Please let me know as it will be in the mid 90's again today.
Thank you,
    Novelist:
    Champion:
  • 246 Answers
Tripping breakers and your cord getting 'noticeably' warm to the touch are both 'bad' signs - and the most likely problem is either your compressor or fan motor is getting ready to 'quit' on you - which constitutes (in most cases with window units) making the smart move toward a 'new' or 'newer used' air conditioner.
There are however a few things you might try:
First - up-plug the AC and take it out of the window
Second - take the outer cover off - so you can see inside real good. Look for 'loose' electrical connections (loose connections generate excess electrical heat) - "tighten" any connections that are loose. Note: be sure and check the plug - see if the prongs are loose/wobbley, (if so you might need a new cord) check where the cord ties into the window unit - check the electrical components to make sure their connections are good and tight - any wires you find 'wire-nutted' together (with those colored plastic wire nuts) - take them apart and 're-do' them - making sure they are tight.
Check the connectors on the"capacitors" (grey/silver/black items from the size of a pack of cigerettes to 2 or maybe 3 times that big) - make sure they are tight on the connectors.
You may have to take the (spades) off the connector and using pliers - crimp them down so they will fit the connectors good and tight.
On the compressor itself - follow the wires (usually 3) to the little removable cap (usually a metal clip holds it in) - take the clip off and pull the plastic cap out and you can see the compressor terminals. Be sure the wires that are attached (usually with wire spades) are good and tight. If they aren't - carefully remove them - re-crimp and re-install - making sure they are tight. Note: in some cases you might need to put a new spade on the wire.
After doing all that - take a water hose and make sure both coils (evaporator where cold air comes out and condenser where hot air comes out) are good and clean. Note: you don't have to be 'real' careful with the water - but try to not get water in the electrical components/wires.
You have to make sure they are both 'real clean,' and of course the filter that goes in front of the evaporator coil must be clean - but you indicated you've already changed that.
Hopefully - you will find some seriously loose connections and once you get them tight and the unit washed real good - you'll be ok, but if it keeps tripping breakers - and the AC cord continues to feel excessively warm to the touch I would think you will need to start thinking about either a Service Tech to repair the AC or buying a new/different one.
As I noted above - if it's a fan motor or a compressor that is bad - you are better off (since your unit is already 7 years old) in my opinion to try and secure a new AC or a fairly new used one - 'especially if it's the compressor.
If it's the fan motor - and your Service Tech gives you a 'fair' price for a changeout, i.e. 'half' what a brand new unit of the same size would cost - then I'd probably let him do that - but try and get a warranty from him of at least 90 days (parts and labor).
Good Luck!
Posted on Jul 06, 2010
My Maytag Portable Air Conditioner Model #M6P09S2B keeps popping my breaker. Can you help me solve this problem?
This can because by a couple of things. An electrical fault within the AV Unit or the electrical circuit the unit is plugged into has other electric appliances on the same circuit. Thereby, overloading that one circuit. Try plugging the unit into another outlet that is on a different circuit. If it trips a circuit breaker then, the problem is within the unit. In which case, you will need to have the unit checked and serviced.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Maytag M6P09S2B Portable Air Conditioner
The trailer did not have a air conditioner in it before the trailer place installed the new dometic air conditioner. The trailer year is a 1976 AMF Skamp. I told the trailer place that I wanted a 15000 btu...
You have too small a cord on it if it's heating up and then popping your breaker. The a/c has am amp rating on it's data tag, read it and then read the amp capacity of your breaker and the cord your using. If the a/c draws more than 80% of the rated amps for the cord and breaker then you need to find another way to power it up with a bigger cord and a bigger outlet. DO NOT just install a bigger breaker, it is sized for the wiring in your home and a bigger amp draw on that wiring could burn your house down.
Jun 17, 2011 | Dometic Rooftop RV Air Conditioner
Internal breaker in the plug keeps clicking off, when i reset it clicks off again. ive replace the Main House breaker, thinking it may be old, but still the inline breaker keeps popping off. this Ac/Heat...
Inspect the wiring and the terminals. There may be a short circuit somewhere. If you have a tester, you may check the continuity of the two wires. Test the wires after the breaker, the part that goes to the unit.
May 05, 2010 | Fedders AER24E7A Air Conditioner
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
Coleman Mach 3 ac unit tries to start compressor & kicks off
50 foot extention cord not a problem IF it is at least 10 gauge and plugged in to a 20 amp circuit
Your compressor is shutting down for a lack of AC voltage would be my best guess
Jul 27, 2009 | Coleman Mach III Air Conditioner
Exact same thing happened to me
the 20 amp circuit should more than handle a 6.5 amp load, the 6.5 is the rating of the operating AC not of the circuit that is required to be attached to it. If the "pop" noise is the breaker tripping the circuit may be miswired, the unit mayhave a short to ground, as the circuit breaker is designed to trip on an over amp situation or a situation where 20 amps is exceeded. Di you verify that the circuit voltage id correct, eg: 220 volt or 110 volts. and that it matches the unit nameplate.
Jul 20, 2009 | Goldstar KG6000R Window Air Conditioner
Amana air conditioner keeps popping its cord breaker
This a ground fault breaker. They do go bad. Is it kicking it all the time or when you plug it in. I replaced a lot of the ground fault plugs. You have to go to the Appliance Parts store to get a new power cord. If you have a problem with thisyour warranty should cover the power cord check your warranty. Rus
Jul 11, 2009 | Amana ACB065R 6000 BTU TOUCH/REMOTE ROMM...
I have three window ACs in my entire mobile home(double wide). One at the back of the house, one in the middle and one in the front. Each one is plugged into its own outlet. If I try to run more than one...
Susan; # A/C units in a mobile hme is a little much to much. I'm surprised it hasn't burned down. Upping yor circuit breaker would cause an extreme fire hazard.
Jul 10, 2009 | Gibson Thru-Wall/Window Air Conditioner
Hitachi RAS09UH randomly pops 15A circuit breaker
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Jul 09, 2009 | Hitachi RAS-09UH Air Conditioner
Samsung AC keeps popping breaker
use larger extention cord with thicker wiring,as short as possiable!
Jun 25, 2009 | Heating & Cooling
Maytag M6Y12F2A Air Conditioner Logo
385 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
