My Canon ink jets are blocked an need to fix this quickly
  • allreef Apr 18, 2008
    It is a canon imageclass mp700 and I have done all the head cleaning maintenance and nothing works. It will only print in black and red
  • jemuel osorio
    jemuel osorio May 11, 2010
    what model of canon and the error messages
    Scholar:
  • 176 Answers
I have fixed my customer canon problem like yours. Try to follow the steps below how to fix.
1) Remove the printer cover
2) If you can see the printer head beside the lift side of the printer there are four holes one for the black and three for the color .If you can remove the printer head remove it.
3) And soak in the warn water the printer head but don't wet the electronic side only the head nozzles to melt the clogged ink that block to the ink to flow.
4) If you can,t remove the head try to use a hair blower to open some holes in the head that block of the dry ink.
Posted on Apr 21, 2008
    Novelist:
    Champion:
  • 214 Answers
Run the printer's Maintenance program and run Deep Cleaning.
Do a print check after each clean as this uses a lot of ink to clean and you don't want to continue after you get a good print result.
Good Luck.
Posted on Apr 18, 2008
Canon printer banding
On your computer, run the Canon printer software, to run a few "print-head-cleaning" cycles, to unclog any blocked ink-jets.
Jun 07, 2011 | Canon PIXMA MX870 Wireless Office...
My Canon MP620 is printing in pink (and a bit of orange) only. All cartridges are at least half full. The big black one is full as are the pink and cyan ones. How can I get the black to function again...
Use the CANON software on your computer to run some "printer maintenance", namely a few "print-head-cleaning" cycles, to try to unclog any blocked ink-jets that are _not_ shooting ink onto the paper.
Jun 04, 2011 | Canon PIXMA MP620 All-In-One InkJet...
The black ink is not printing on my canon mp510 even though there is ink.
sounds like the black ink jet is blocked with dried ink, use the maintaince tool, should be in the canon software
Sep 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Just refill our black ink for canon pixma ip 1200 and it gives out lines in beetwen image. How can i fix? it says it needs to unclogged but i kept cleaning through maintenance tab and result is still the...
Canon recommends genuine canon ink jet cartridges. If you bought a remanufactured ink jet cartridge and it did this, I would return it immediately.
But, since you filled it yourself, there's no recourse with the ink company, I don't believe.
Even if you were successful with refilling, they can only be refilled 2 or 3 times at best.
Jul 10, 2010 | Canon PIXMA iP2000 InkJet Printer
Hi. No magenta or cyan printing on my canon pixma 750. used the maintenance cleaning function and head refreshing to no avail. Any ideas,thanks Mark
Sounds like the ink jet cartridges need to be replaced. Cleaning will not solve the problem after the ink is depleted, and if the ink were low, the cleaning process uses up a lot of ink.
Good luck on replacing the ink jet cartridges.
Jul 16, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Printouts missing top part of words
Use the CANON "Printer Utility" software to run a "head-cleaning" cycle -- some of the jets that shoot the ink have become blocked.
Jun 11, 2010 | Canon BJC 2100 InkJet Printer
After cleaning the nozzles, the quality of print is still very poor. What should we do?
HTML clipboard HTML clipboardHi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Canon Office Equipment & Supplies
My Canon ip1800 ink absorber is full is there a quick fix
No .You must replace waste ink tank.
to get printout
Jul 01, 2009 | Canon PIXMA iP1300 Printer
Canon ip4300 one color will not work can you help
have u refilled the toner. just try it. otherwise it might have blocked somewherelse. try
Apr 18, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
How do you clean the ink jets on a cannon S820?
Best way I know of cleaning blocked heads is to run them through a cycle in an ultrasonic bath filled with warm water. Failing that then you will need to replace them.
Dec 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
296 people viewed this question
k24674
