Question about Philips 9P6040C 60" Rear Projection Television
Screen is all shrunken and in one corner...Convergence Problem... i think
On power up the picture is about one third the size of the actual screen size. The edges of the picture that is displayed are non uniform and almost have a rounded appearance. The picture displayed increases and decreases in size at random. After the set warms the picture gets larger and becomes more stable - sometimes. However the full picture size is never achieved. The color is also strange, but i think this is due to the strange size. I have read several other posts that say this is a convergence type problem with IC's or the Convergence Board. I looked for parts but there are no specifics, and i dont know exactly what to look for either.
  • Philips Master
  • 3,459 Answers
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Posted on Jul 16, 2008
The picture does not fit the entire screen size of the television
Possible that the power supply is faulty as a low +B- main power can result in the picture reducing in the screen. Also if there is fault in the convergence section, failure of the drivers, failure of the capacitors, it is possible that the size can reduce.
Feb 04, 2011 | Televison & Video
Color is fine but in top right corner have blue and yellow distortion but the rest of the screen picture is ok
The tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment anywhere in the picture screen.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.
Oct 09, 2010 | Hitachi 60DX10B 60" Rear Projection...
The top 10 inches of my screen is breaking into separate bands of grn/mag/yellow that continue across the tv till half way and then it skews to the top right corner. It started doing this about 2 weeks...
Ur convergence is dead.U Know how to solders?Must replaced the 2 Convergence ICS and all it resistors.Tries Tv Repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Jan 27, 2010 | Hitachi 53UDX10B 53" Rear Projection...
How do I make my tv pic full screen? My tv programs are shrunken to small screen...
GO TO MENU ON UR REMOTE CONTROL AND SELECT PICTURE SETTING .....
THIS OPTION WILL GIVE U THE PICTURE SIZE ON UR SCREEN U LIKE TO SEE....REMEMBER NOT ALL PROGRAMS ON TV ARE IN FULL SCREEN MOODE
Nov 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Tv model AT 2002 THE SECREEN IS SHRUNKEN BRAND: APEX
Generally vertical issues on a set are from a bad panel
Nov 24, 2017 | Apex Digital Televison & Video
Picture appears concave and shrunken and pulses in size
Replace Both of your STK convergence ICs STK392-570 If this is not number on your s use what it has on them. you can call MATs 1-800-628-1118 o Main STK is what is going bad when IC goes out all together TV will shut down and will not come on. So replace BOTH STKs ASAP! you will also need Heat sink compound to put on back of New ICs.
Aug 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
RCA D61W20 Projection Television with ITC222 chassis Here is the whole thing , took this machine apart last night the mirror is in good shape cleaned the lenses, picture is much brighter now! However still...
unfotunatly the itc222 has no convergence ics it uses a series of trsansiitors. the fact that u have some areas of the screen clear may mean you need a technician to do a service alignment. when you go into setup does the convergence crosshairs move up and down and side to side on both the blue and red? if they do their may not be a problem with the power board. ONe more thing if you replace this board you will still need a technician to do a service alighnment
Jun 16, 2009 | RCA Televison & Video
TV Picture problems
replace all caps in vertical area, if problem stays, try replacing pumpup diode and vertical. if still same problem check drives goin to the vert, and vcc goin to it.
Apr 09, 2008 | Televison & Video
Picture at the top left corner curling in
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 21, 2007 | Sony KP-41T65 41" Rear Projection...
Philips 9P6040C 60" Rear Projection Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
